I wanted to kick things off by getting into PCB design by following someone's schematic and code. I guess I messed up by trusting the person that the code was correct and the most efficient way of doing things below I'll include the code and display+wiring diagram.
Display:
Amazon
Wiring Diagram:
open in new tap for higher res.
Code:
#include "U8glib.h" //Library for display
#define MOSFET_Pin 2
#define Bat_Pin A0
#define Res_Pin A1
U8GLIB_SH1106_128X64 u8g(); // I2C interface for OLED
float Capacity = 0.0;
float Res_Value = 5.0;
float Vcc = 4.410; //Measure it and change
float Current = 0.0;
float mA=0;
float Bat_Volt = 0.0;
float Res_Volt = 0.0;
unsigned long previousMillis = 0;
unsigned long millisPassed = 0;
float sample1 =0.000;
float sample2= 0.000;
int x = 0;
int row = 0;
void draw(void) {
u8g.setFont(u8g_font_fub14r);
if ( Bat_Volt < 1){
u8g.setPrintPos(10,40);
u8g.println("No Battrey");
else if ( Bat_Volt > 4.3){
u8g.setPrintPos(3,40);
u8g.println("High Voltage");
else if(Bat_Volt < 2.9){
u8g.println("Low Voltage");
else if(Bat_Volt >= 2.9 && Bat_Volt < 4.3 ){
u8g.drawStr(0, 20, "V: ");
u8g.drawStr(0, 40, "I: ");
u8g.drawStr(0, 60, "mAh: ");
u8g.setPrintPos(58,20);
u8g.print( Bat_Volt,2);
u8g.println("V");
u8g.setPrintPos(58,40);
u8g.print( mA,0);
u8g.println("mA");
u8g.setPrintPos(58, 60);
u8g.print( Capacity ,1);
void buz()
digitalWrite(9, HIGH);
delay(100);
digitalWrite(9, LOW);
delay(10);
buz();
pinMode(A2,INPUT_PULLUP);
pinMode(A3, INPUT_PULLUP);
pinMode(MOSFET_Pin, OUTPUT);
pinMode(9, OUTPUT);
digitalWrite(MOSFET_Pin, LOW);
for(int i=0;i< 100;i++)
sample1=sample1+analogRead(Bat_Pin);
delay (2);
sample1=sample1/100;
Bat_Volt = 2* sample1 *Vcc/ 1024.0;
sample2=sample2+analogRead(Res_Pin);
delay (2);
sample2=sample2/100;
Res_Volt = 2* sample2 * Vcc/ 1024.0;
buz();
Serial.println( "Warning High-V! ");
buz();
Serial.println( "Warning Low-V! ");
else if(Bat_Volt > 2.9 && Bat_Volt < 4.3 ) {
digitalWrite(MOSFET_Pin, HIGH);
millisPassed = millis() - previousMillis;
Current = (Bat_Volt - Res_Volt) / Res_Value;
mA = Current * 1000.0 ;
Capacity = Capacity + mA * (millisPassed / 3600000.0);
previousMillis = millis();
row++;
x++;
delay(100);
u8g.firstPage();
do {
draw();
} while( u8g.nextPage() );
PCB Printed by JCL follows the same schematic above. I ran this code on an "Arduino pro micro" Arduino mini knockoff. Therefore, the pinout might be different from the pro mini. The OLED stays dark and nothing is written to the screen. All I get in my serial is "Warning Low-V!" and I'm not sure how to diagnose this further as this is my first project including a display. I appreciate and help I am given! Let me know if you need anything else to help diagnose this.
