Thanks for the support guys:
Arduino Uno attached to PC and 9v battery
The RHOS 800L has a flashing light every second
SIM TXD to Pin 10
SIM RXD to Pin11
Just using the software serial example code but have adjusted the baud rate to 9600
sent AT command and got OK response
I may need to look at my code some more.
I may have possibly suffered new starter syndrome and bitten off more than I can chew as a first project.
nowhere near enough juice in a 9v PP3 battery if that’s what you mean.
How are deriving the 5V needed to the modem, again, not through the Arduino 5v regulator.
The modem needs a good strong 5v @2A independent of the processor.
i’ve been using SIM5320x (3G) for a couple of years, but I think 4G modems are only just beginning to appear. You’ve got at least 5 years with 3G networks..
Try Tinysine Electronics, because I’ve been on him to put together a 4G bundle for Australia.
Thank you all for the help - I have it "working"
You were right:
The GSM module was 2G and couldn't connect to my local network as thje signal strength was non existent. a new SIM808 board and SUCCESS! Sort of...
(I thought this would all be easy lol)
remember I'm painfully new...
The plan is to have the arduino and GSM module hidden in a base unit with a switch on a bell, when the bell is rung, switch connects and a standard SMS message is sent to my mobile.
It'a for a fun gift - the message will read "get the boss a coffee"
I have it set up and have borrowed the code from an online tutorial but (and this is where my novice lack of knowledge is killing me) does the arduino ALWAYS have to be connected to my PC for this to work?
Once I load up the sketch - as long as it is connected to my PC it works, but if I unplug... nothing.
UNO and GSM are powered seperately so no issues there.
Where am I going wrong?
Also I can't seem to get the sms to repeat (if the button/bell is pressed a second time later)?
here's the code I've borrowed (and no - that's not my real mobile number)
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 11); // RX, TX
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.println("Good to go!!");
// set the data rate for the SoftwareSerial port
mySerial.begin(4800);
pinMode(2,INPUT_PULLUP);
while (digitalRead(2) == HIGH) {;}
mySerial.write("AT+CMGF=1"); mySerial.println();
delay(100);
mySerial.write("AT+CMGS="); mySerial.write('"'); mySerial.write("0787654321"); mySerial.write('"'); mySerial.println();
delay(100);
mySerial.write("Go Get Boss A Coffee");
mySerial.println(char(26));
void loop() { // run over and over
if (mySerial.available()!=0) {
Serial.write(mySerial.read());
if (Serial.available()) {
mySerial.write(Serial.read());
As always I honestly appreciate the help - I live in the UK lake district and there are no classes or learning centres I can go to so you folks are my only help.
