Thanks Graynomad - yes, nice board ... all the pieces are coming together, but the one that still eludes me (for now) is "time".
Join the club, too many projects and too few years
Rob
This would be great for very fast data loggers.
Cheers!
These are simplified schematics of a datalogger and a pattern/signal generator talented hackers may try out..
1. Waveform/pattern generator
i. you write the required pattern into the ramdisk (EN=0) in a standard way
ii. you read the pattern out of the ramdisk with /RD used as the "clock" (EN=1)
iii. you may use an external clock generator, or you may generate the clock from the mcu (ie. via PRG_OSC pin)
iv. the address rolls over to zero after reaching 8MB, so the pattern will repeat itself
v. mind the 74273 (or an another type) is a "register", not a "latch"
vi. you may generate 10million patterns per second max.
2. Datalogger
i. you write the starting address (ADCEN=0) in a standard way
ii. by "clocking" the /WR signal you may write the ADC data (or "any" data) into the ramdisk (ADCEN=1)
iii. you have to organize the ADC conversion based on the ADC chip you use (CONV rising edge writes ADC to the latch)
iv. you may read the data in a standard way out of the ramdisk
v. you may sample 15million samples per second max.
- Below you may see how to connect two 8MB Ramdisk modules - 8bit and 16bit data bus versions.
PS: With 16bit data bus version you may enhance the datalogger/pattern/waveform examples to 16bit width easily..
PS1: The minimal number of data bits used is 4 (D0-D3), ie. you want to generate 4bit patterns only
PS2: Provided as-is, no warranties of any kind
Andreas,
the wiring - read this topic first: Parallel library for Due External Memory Bus/Static Memory Controller - Arduino Due - Arduino Forum
I recommend to connect the ramdisk to the DUE's External Memory Bus (and to use the existing driver, ie.
https://github.com/delsauce/ArduinoDueParallel ). Later on you may access the EMB registers directly to avoid the C++ overheads (in order to speed up the transfers).
See this link for wiring details (you have to find the proper header pins for the specific EMB function).
http://forum.arduino.cc/index.php?topic=152644.msg1146753#msg1146753
Ramdisk DUE EMB (Function)
D0-D7 D0-D7
/RD NRD
/WR NWE
/DATA A0
/MS GND
3.3V 3.3V
GND GND
PS:
D0-D7 does not mean digital pins D0-D7 on DUE, but the data signals D0-D7 on the DUE's EMB bus.
A0 means Address line A0 on the DUE's EMB bus.
NRD, NWE means NRD and NWE on DUE's EMB bus.
See: 8MB Ramdisk (external RAM) for Arduino.. - #15 by pito - Other Hardware Development - Arduino Forum - the picture says "EMB signals D0-D7"
PS1:
Do not use the bitbanging example for arduino - that is just an example for people with 3.3V 8bitters.
You may use the code snippets for DUE there in my above posts - mind that code is not a sketch which will compile, it is an example how to use the DUE's EMB library functions (see above topics) with the ramdisk, you have to add all necessary stuff around (based on your actual requirements).
PS2:
Do it step by step. First learn how to use the DUE's EMB with the ramdisk. Write a small sketch where you write/read data into/from the ramdisk, do experiments with the timing settings.. (I can assist you in a separate topic or offline).
PS3: (!!!)
Pls mind the wire length is important while chasing the nanoseconds
I've been running 2 modules in parallel on the same solderless breadboard with ~5cm long data lines and 10-15cm long NRD,NWE,A0,A1 (fubarino @120MHz) - see the first picture of this topic.
Use as short as possible wires when connecting a memory device.
PS4:
This is an example code which runs fine on DUE (UPDATED 22.5.2014):
// A DUE EMB Example for 8MB Ramdisk v.1.1
// Library used: https://github.com/delsauce/ArduinoDueParallel
// DUE at 84MHz (12ns clock)
// IDE 1.5.6r2
// Wiring: 11cm long jump wires and solderless breadboard
// Provided as-is, no warranties of any kind
// Pito 5/2014
/* Wiring:
RDisk DUE's header DUE's EMB signal name
D0-D7 PIN34-PIN41 D0-D7
/WR PIN45 NWE
/RD PWM4 NRD
/DATA PWM9 A0 (A0=0 wr/rd Data, A0=1 wr Addresses)
/MS GND GND
3.3V 3.3V
GND GND
DUE's EMB signal name MCU I/O line
D0 PC2
D1 PC3
D2 PC4
D3 PC5
D4 PC6
D5 PC7
D6 PC8
D7 PC9
NWE PC18
NRD PA29
A0 PC21
#include <Parallel.h>
typedef union {
unsigned long value;
struct {
unsigned char nib1: 4; // lowest nibble
unsigned char nib2: 4;
unsigned char nib3: 4;
unsigned char nib4: 4;
unsigned char nib5: 4;
unsigned char nib6: 4;
unsigned char nib7: 4;
unsigned char nib8: 4; // highest nibble
} nibbles;
// Setting up the rd/wr starting Address (8388607 max)
int set_address(unsigned long address){
nibbles temp;
temp.value = address;
Parallel.write(1, temp.nib6); // addr[23..20]
Parallel.write(1, temp.nib5);
Parallel.write(1, temp.nib4);
Parallel.write(1, temp.nib3);
Parallel.write(1, temp.nib2);
Parallel.write(1, temp.nib1); // addr[3..0]
// Configure parallel bus for 8bits, no CS, A0, and NRD and NWE
Parallel.begin(PARALLEL_BUS_WIDTH_8, PARALLEL_CS_1, 1, 1, 1);
// Configure bus timings.. EXPERIMENTAL
Parallel.setAddressSetupTiming(1,1,1,1);
// NWE, NCSWE, NRD, NCSRD - we do not use NCSs
Parallel.setPulseTiming(7,1,7,1);
// CycleTiming = PulseTiming + AddressSetupTiming + 1
Parallel.setCycleTiming(9,9);
// make a dummy read
Parallel.read(0);
// set the Serial
unsigned long i, elapsedw, elapsedr;
Serial.println("START OF THE TEST");
Serial.println("WRITING BYTES TO RAMDISK");
// Write 1 million data = 234 from Address=4444444
elapsedw = millis();
set_address(4444444L);
for(i=0; i<1000000; i++){
Parallel.write(0, 234);
elapsedw = millis() - elapsedw;
Serial.println("READING BYTES FROM RAMDISK");
// Read and sum 1 million of data from Address=4444444
elapsedr = millis();
unsigned long sum = 0;
sum = sum + Parallel.read(0);
elapsedr = millis() - elapsedr;
Serial.print("SUM = ");
Serial.println(sum);
Serial.print("ELAPSED WRITE = ");
Serial.print(elapsedw);
Serial.println(" msec");
Serial.print("ELAPSED READ = ");
Serial.print(elapsedr);
Serial.println("TEST STOP");
while(1);
START OF THE TEST
SUM = 234000000
ELAPSED WRITE = 680 msec
ELAPSED READ = 846 msec
TEST STOP
There is an undocumented feature with the Parallel driver - the PARALLEL_CS_NONE parameter sets NRD/NWE timing to 12ns regardless of the timing settings. As a workaround use PARALLEL_CS_1, even we do not use any CS.
Above sketch updated.
Pito, the updated sketch works perfectly!
Thx so much for your patience and support!
Andreas
Great!
I've been messing a little bit with the Parallel driver, as it seemed to me the driver is slow.
I did following:
Comment out in Parallel.cpp:
//__attribute__((optimize("O0"))) void ParallelClass::write(uint32_t offset, uint8_t data)
// *((volatile uint8_t *)(_addr + (offset&0x00FFFFFF))) = data;
//__attribute__((optimize("O0"))) uint8_t ParallelClass::read(uint32_t offset)
// return *((volatile uint8_t *)(_addr + (offset&0x00FFFFFF)));
And replace in Parallel.h :
void write(uint32_t offset, uint8_t data) ;
uint8_t read(uint32_t offset);
with:
*((volatile uint8_t *)(_addr+offset)) = data;
return *((volatile uint8_t *)(_addr+offset));
Then I get following elapsed time for the above example sketch:
START OF THE TEST
SUM = 234000000
ELAPSED WRITE = 321 msec
ELAPSED READ = 262 msec
TEST STOP
There is still an issue as the NWE timing does not react to timing parameter changes properly. The NRD timing works fine, it seems.
I've added a delay(500) before the "for loop" measurements (to eliminate the potential influence of print) and the result of above example sketch is:
START OF THE TEST
SUM = 234000000
ELAPSED WRITE = 226 msec
TEST STOP
That means one write cycle (inclusive "for loop") takes 226ns (or 4.4MBytes/sec).
Moreover, I did a measurement of the actual NWE signal High/Low durations during the 1mil "for loop" vs. the NWE timing parameters settings (the resolution of my LA is 5ns):
A, P, C L H L+H MBytes/sec
1, 2, 4 25 205 230 4.35
1, 4, 6 45 180 225 4.44
1, 8,10 95 135 230 4.35
1,16,18 185 40 225 4.44
1,32,34 380 25 405 2.47
where
A - NWE setAddressSetupTiming
P - NWE setPulseTiming
C - NWE setCycleTiming
L[ns] - NWE Low - active low pulse (write pulse)
H[ns] - NWE High - the overhead of the for..loop
How to decipher that results?? Any hint?
PS: the "NWE Low" copies the setPulseTiming well (NWE Low = 12ns * P), but why the L+H is constant or "framed" or "limited"??
We found out that for experimenting with DUE's EMB bus timings it is better to fill in the memory with random numbers. Below find the sketch.
// DUE EMB Example for 8MB Ramdisk v.1.1
// 1M BYTES RANDOM WRITE/READ
// Pito 7/2014
/* Wiring:
/WR PIN45 NWE
/RD PWM4 NRD
/DATA PWM9 A0 (A0=0 wr/rd data, A0=1 wr addresses)
/MS GND GND
Parallel.write(1, address >> 20); // addr[23..20]
Parallel.write(1, address >> 16);
Parallel.write(1, address >> 12);
Parallel.write(1, address >> 8);
Parallel.write(1, address >> 4);
Parallel.write(1, address); // addr[3..0]
// We do not use any real addressing
Parallel.setPulseTiming(5,1,7,1);
// better read datasheet for CycleTiming:
Parallel.setCycleTiming(7,9);
Parallel.read(0);
// set the Serial
unsigned i;
unsigned sumr, sumw, elapsedw, elapsedr;
unsigned char data;
randomSeed(micros());
Serial.println("WRITING 1Mil RANDOM BYTES TO RAMDISK");
// Write 1 million random data
sumw = 0;
set_address(0L);
data = random(256);
Parallel.write(0, data);
sumw = sumw + data;
Serial.println("READING AND SUM 1Mil RANDOM BYTES FROM RAMDISK");
// Read and sum 1million of data from Address=0L
sumr = 0;
set_address(0L);
sumr = sumr + Parallel.read(0);
Serial.print("SUM_W = ");
Serial.println(sumw);
Serial.print("SUM_R = ");
Serial.println(sumr);
Serial.println(" ");
//while(1);
I've got a similar one (but 16Mb serial). Might be of interest to someone. Products | Dimitech - look for DTX2-5055C
sorry for necroposting but I was hoping to buy one of these but they seems out of production... so what do you think about this + this?
basically is a retail sdr ram TSOP-54 chip mounted on a DIP-54 adapter for breadboard. the speed it's not a problem because according to the datasheet which on page 20 states
- For operating frequencies ≤ 45 MHz, tCKS = 3.0ns
seems we can get quite slow...
refresh is a problem neither because this module also feature autorefresh. They are also 3.3V ±0.3V!!!
mounting can be optionally made by the adapter retailer so even n00bs like me could afford prototyping. cost seems reasonable too... If this solution is working we can access infinite RAM on our DUE module, useful for example for big image manipulation (e.g. 10MP camera sensor)! in this case I'm talking about 512MB (64Mb) in 64MX8 configuration.
To quench the thirst of pin of this beast we could use shift registers or multiplexers for data and address
I've seen ram modules even in commercial cheap-o stuff http://youtu.be/1EuBRmfJLSk @19:37 in the upper part. and here the same module mounted over a ram bank http://old-pc-museum.narod.ru/olderfiles/1/64Mb_eliteMt_m12l64164a-8t_big.jpg.
The sdrams are quite cheap, but not easy to interface. If the DUE supports an sdram interface then it would be doable, otherwise, you have to write a bitbanging driver for it. We did it once with pic32mx and the result was moderate.
The 8MB ramdisk uses an PSRAM - it is an sdram with pure sram interface. Therefore you work with static sram design while utilising large sdram volume.
The static srams are expensive - 8MB of static sram would cost you a lot of money.
Also, when talking micro-controllers, you want to save the i/o pins for something else. An 8MB sram needs about 34 pins in an 8bit data width configuration.
So, you have to balance all possible requirements..
