Hi, I am planning to use this 9 Axis gyro, accelerometer and compass module.
Here I found a cheaper one with the same code MPU9150 but the title says only gyro sensor.
Do they two work the same?
They should work the same.
The are the same sensor.
The Sparkfun module needs 3.3V to work.
The DealExtreme has a voltage regulator onboard, so you can power it with 5V.
These costs between 11 and 12 dollars:
Thank you everyone for your time.
