I'm trying to generate two PWM signals that are 90 degrees out of phase using Arduino Mega but get stuck. I know how to generate 180 degrees but I don't really know how to modify that design and achieve a 90 degree out of phase signal. Thank you!
The Interrupt library is only used for the push-button ISR's. I figured folks would know to grab it from the Internet. I'll modify the Article to explain that in the Code section. Apologies for any confusion.
Alternatively, you could call either Start_PSPWM routine from your own code to run the project. In fact, you can dump all button and direction interface wiring and just call one of the Start routines (Fwd or Rev) and the Stop routine when needed. No interrupts required at all for that use case. Then you can see the code run.
