A bluetooth servo/latch system
Hi!
I was looking to start a project that does the following:
  1. Device is less than 200 meters away (more than likely <150 meters), outdoors with no obstructions
  2. Using bluetooth(?) send command to move servo, kind of like a latch system
  3. Close latch
Needs to be battery powered
I'm unsure of the range and capabilities - would this be possible? If so, are there any components that I would need other than the arduino uno r3 and would anyone have recommendations?
Welcome to the forum
A question for you
Forgetting the Arduino for now, are you able to establish communication between 2 Bluetooth devices such as your 'phone and your PC at a range of 200 metres ?
Thank you!
Maybe 200m was a bit much, but realistically 100m using a HM-10 would be fine? Then use one of those BT android apps to send a simple command over - it's completely open area so I would think it's alright?
In theory maybe, in real live .. no way. WiFi will work, so ESP32 would be a good startingpoint.
Hello baardie
Welcome to the world's best Arduino forum ever.
Take a search engine of your choice and ask the WWW for 'arduino remote control' to collect some data to be sorted out to get the needed information.
