Who can help me slove this problem
I have two boards; the other one functions perfectly and the program is intact.
I am still just a student, and I do not understand much about ESP32 development
Serial Port Output:
invalid header: 0xffffffff
ets Jul 29 2019 12:21:46
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
Error log:
PS E:\Desktop\Project-ESPNow2.2> esptool --chip esp32 --port COM8 --baud 115200 write_flash
--flash_mode qio --flash_freq 80m --flash_size 4MB
0x1000 "E:\Desktop\Project-ESPNow2.2\Project-ESPNow.ino.bootloader.bin"
0x8000 "E:\Desktop\Project-ESPNow2.2\Project-ESPNow.ino.partitions.bin"
0x10000 "E:\Desktop\Project-ESPNow2.2\Project-ESPNow.ino.bin"
Warning: Deprecated: Option '--flash_mode' is deprecated. Use '--flash-mode' instead.
Warning: Deprecated: Option '--flash_freq' is deprecated. Use '--flash-freq' instead.
Warning: Deprecated: Option '--flash_size' is deprecated. Use '--flash-size' instead.
Warning: Deprecated: Command 'write_flash' is deprecated. Use 'write-flash' instead.
esptool v5.1.0
Connected to ESP32 on COM8:
Chip type: ESP32-D0WD-V3 (revision v3.1)
Features: Wi-Fi, BT, Dual Core + LP Core, 240MHz, Vref calibration in eFuse, Coding Scheme None
Crystal frequency: 40MHz
MAC: 5c:01:3b:67:f0:34
Stub flasher running.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00007fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x00010000 to 0x00105fff...
Flash parameters set to 0x002f.
SHA digest in image updated.
Wrote 24976 bytes (15971 compressed) at 0x00001000 in 1.5 seconds (134.2 kbit/s).
Input MD5: 798d0027412979c8218ee34e0ef33421
Flash MD5: 39d83f05ed8985d4e99e57b67b75669a
Hard resetting via RTS pin...
A fatal error occurred: Write failed, the written flash region is empty.
PS E:\Desktop\Project-ESPNow2.2> esptool --chip esp32 --port COM8 flash_id
Warning: Deprecated: Command 'flash_id' is deprecated. Use 'flash-id' instead.
esptool v5.1.0
Flash Memory Information
Manufacturer: 85
Device: 2016
Detected flash size: 4MB
Flash voltage set by a strapping pin: 3.3V
Hard resetting via RTS pin..```
