Hey folks, so I have purchased some ESP32S3 dev boards from AXpress…. Normally C3’s which I ahev never had issues with, but of the 5 of these boards, two have suddenly start restarting with the following error
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x7 (TG0WDT_SYS_RST),boot:0x2b (SPI_FAST_FLASH_BOOT)
Saved PC:0x40043ac8
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0xfb0
load:0x3c8700ff,len:0xaf440
Invalid image block, can't boot.
ets_main.c 329
Now I tried succesfully flashing new boatloader, along with erasing flash first of course, and then I installed a sketch example of IDE and sadly, there is no difference!
(esptool-env) C:>esptool --port COM21 --baud 460800 write_flash -z 0x1000 firmware.bin
Warning: Deprecated: Command 'write_flash' is deprecated. Use 'write-flash' instead.
esptool v5.2.0
Connected to ESP32-S3 on COM21:
Chip type: ESP32-S3 (QFN56) (revision v0.2)
Features: Wi-Fi, BT 5 (LE), Dual Core + LP Core, 240MHz, Embedded Flash 4MB (XMC), Embedded PSRAM 2MB (AP_3v3)
Crystal frequency: 40MHz
USB mode: USB-Serial/JTAG
MAC: a0:f2:62:ec:63:4c
Stub flasher running.
Changing baud rate to 460800...
Changed.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x001adfff...
Wrote 1753904 bytes (1148251 compressed) at 0x00001000 in 10.4 seconds (1348.5 kbit/s).
Hash of data verified.
Hard resetting via RTS pin...
Have I purchased faulty boards? I had successfully flashed them a few times without issue…. so they were ok, just not any more!
Serial comms were working well along with BLE and other functions (built in nanopixel etc).
One more thing, could this be settings within IDE?
Thanks
