Hello this is my first question what am I doing wrong? I need to figure out what I'm missing. If you know please tell me so I can learn from this. Heres the code:
void czr(int czr) {
void doubleclick() { // what happens when button is double-clicked
int CO2 = czr.CO2();
ScreenConfigtextco2(2, 1500, "2 Click", CO2 / 1000, "%");
void singleclick() { // what happens when the button is clicked
ScreenConfigtextco2(2, 1500, "1 Click", CO2 / 1000, "%");
void longclick() { // what happens when buton is long-pressed
ScreenConfigtextco2(2, 1500, "Long Click", CO2 / 1000, "%");
Welcome to the forum
Look at your code formatted slightly differently
void czr(int czr)
void doubleclick()
void singleclick()
void longclick()
Do you see how the doubleClick() function, and others, are defined within the czr() function ?
In future, please post a your whole sketch rather than a snippet, and the full error message copied from the IDE using the convenient button
Ok no problem. So, another question. If that's the case, should I combine all the 4 pieces of code I have and then edit the code from there? or should I keep the four parts of code separate? all four pieces of code do different things.
Thank you very much I'll go look at those right now.
