A generate question about ESP32 touch screen touch_calibrate()
Hi all.
I found that some sketches work on ESP32 touch screen with function of touch_calibrate(), and some without touch_calibrate(), why?
and even the former doesn't works fine without a function of touch_calibrate(), why?
I've tested tft.setRotation(0/1); didn't find reason yet.
the former seems works without tft.setRotation(0); ?
Thanks
Adam
touch_calibrate();
This [ touch_calibrate(); ] seems to be a user-defined function... (from this link)
  Sketch to generate the setup() calibration values, these are reported
  to the Serial Monitor.
  The sketch has been tested on the ESP8266 and screen with XPT2046 driver.
#define TOUCH_CLK 18 // yellow
#define TOUCH_CS 21 // green Chip select pin (T_CS) of touch screen
#define TOUCH_DIN 23 // mauve
#define TOUCH_DO 19 /// purple
#include <SPI.h>
#include <TFT_eSPI.h>      // Hardware-specific library
TFT_eSPI tft = TFT_eSPI(); // Invoke custom library
  // Use serial port
  // Initialise the TFT screen
  tft.init();
  // Set the rotation to the orientation you wish to use in your project before calibration
  // (the touch coordinates returned then correspond to that rotation only)
  tft.setRotation(1);
  // Calibrate the touch screen and retrieve the scaling factors
  touch_calibrate();
  // Replace above line with the code sent to Serial Monitor
  // once calibration is complete, e.g.:
  uint16_t calData[5] = { 286, 3534, 283, 3600, 6 };
  tft.setTouch(calData);
  // Clear the screen
  tft.fillScreen(TFT_BLACK);
  tft.drawCentreString("Touch screen to test!",tft.width()/2, tft.height()/2, 2);
void loop(void) {
  uint16_t x = 0, y = 0; // To store the touch coordinates
  // Pressed will be set true is there is a valid touch on the screen
  bool pressed = tft.getTouch(&x, &y);
  // Draw a white spot at the detected coordinates
  if (pressed) {
    tft.fillCircle(x, y, 2, TFT_WHITE);
    //Serial.print("x,y = ");
    //Serial.print(x);
    //Serial.print(",");
    //Serial.println(y);
// Code to run a screen calibration, not needed when calibration values set in setup()
void touch_calibrate()
  uint16_t calData[5];
  uint8_t calDataOK = 0;
  // Calibrate
  tft.setCursor(20, 0);
  tft.setTextFont(2);
  tft.setTextSize(1);
  tft.setTextColor(TFT_WHITE, TFT_BLACK);
  tft.println("Touch corners as indicated");
  tft.setTextFont(1);
  tft.println();
  tft.calibrateTouch(calData, TFT_MAGENTA, TFT_BLACK, 15);
  Serial.println(); Serial.println();
  Serial.println("// Use this calibration code in setup():");
  Serial.print("  uint16_t calData[5] = ");
  Serial.print("{ ");
  for (uint8_t i = 0; i < 5; i++)
    Serial.print(calData[i]);
    if (i < 4) Serial.print(", ");
  Serial.println(" };");
  Serial.print("  tft.setTouch(calData);");
  tft.setTextColor(TFT_GREEN, TFT_BLACK);
  tft.println("Calibration complete!");
  tft.println("Calibration code sent to Serial port.");
  delay(4000);
rotate0
  tft.setRotation(0);            // 0 vertical / 1 horizontal
rotate1
  tft.setRotation(1);            // 0 vertical / 1 horizontal
Thanks.
Is there an universal touch_calibrate code?
I'll test TFT_eSPI's.
and some display no need any calibrate and just work fine, like many of TFT_eSPI's examples.
This library function seems to find the corners.
Thanks.
