A more smooth update of LCD
I have just built the project here TDS Sensor & Arduino Interfacing for Water Quality Monitoring
The problem is that the code makes the LCD to turn off and update in a flickering way. I want a smooth continious updating of the values. How do I change the code?
#include <EEPROM.h>
#include "GravityTDS.h"
#include <LiquidCrystal.h>
#include <OneWire.h>
#include <DallasTemperature.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
#define ONE_WIRE_BUS 7
#define TdsSensorPin A1
OneWire oneWire(ONE_WIRE_BUS);
GravityTDS gravityTds;
DallasTemperature sensors(&oneWire);
float tdsValue = 0;
    lcd.begin(16,2);
    sensors.begin();
    gravityTds.setPin(TdsSensorPin);
    gravityTds.setAref(5.0);  //reference voltage on ADC, default 5.0V on Arduino UNO
    gravityTds.setAdcRange(1024);  //1024 for 10bit ADC;4096 for 12bit ADC
    gravityTds.begin();  //initialization
    sensors.requestTemperatures();
    gravityTds.setTemperature(sensors.getTempCByIndex(0));  // set the temperature and execute temperature compensation
    gravityTds.update();  //sample and calculate
    tdsValue = gravityTds.getTdsValue();  // then get the value
    Serial.print(tdsValue,0);
    Serial.println("ppm");
    Serial.print("Temperature is: ");
    Serial.print(sensors.getTempCByIndex(0));
    lcd.setCursor(0, 0);
    lcd.print("TDS: ");
    lcd.print(tdsValue,0);
    lcd.print(" PPM");
    lcd.setCursor(0, 1);
    lcd.print("Temp: ");
    lcd.print(sensors.getTempCByIndex(0));
    lcd.print(" C");
    delay(1500);
    lcd.clear();
Never use clear in the loop.
Always put the static stuff, TDS PPM etc., in setup
Only update what needs updating, i.e. the values.
You should not use lcd.clear. instead you should place the cursor at the place where the changing number should be and then overwrite the old number with the new one.
The things that do not change (your text) should be printed to the lcd in setup.
Put five "spaces" after PPM on this line:
    lcd.print(" PPM     "); // five spaces added so range can be 0 to -XXXX
Comment-out this line:
    // lcd.clear(); // commented-out
[edit]
And put six "spaces" after C on this line:
    lcd.print(" C      ");
Here is an example, if it can help : exemple_pour_francky_youpy_v2 - Wokwi ESP32, STM32, Arduino Simulator
An improvement to this code would be to first read all temperatures, then update all values on the lcd at once
Thanks!
Thank you! Must try this! Much appreciated!
Thanks you!
Not tried yet but it seems correct
