raschemmel:
judging from your posts you are looking for a quick and dirty solution and not really interesting in building anything complicated.
Have you actually built any circuit yet ?
Yes I have built the circuit I posted in my original post. It works fine to detect noise close-up such as a clap within 12 inches of the mic, although the output signal was not to my needs (it was not schmitt triggered)
In answer to your other point here (and your previous question on page 2 of thread), it's not a question of whether I'm interested in building anything complicated, the application in question which I described in previous posts in this thread, apologies if you missed this, is that I'm building a multisensor to be installed into each room / area within the home, and because of interest from others online, I am trying to keep the design cheap and simple. Audio sensing is not core to the project, but I do want it to be as good as possible given the space restraints within the housing as well as the cost for others to make.
You can see the project here if interested: youtube link
For the sake of context, the heart of this multisensor is PIR & microwave. Its core function will be to determine if someone is in the room. The idea of adding an audio circuit is to improve the presence sensing. I'm completely aware that noise from other rooms, street noise, thumping from above floors, etc., not to mention intentional room noise such as television / radio / music will mean it's not possible to detect presence by audio with a high degree of accuracy. So the application purposefully calls for audio sensing as a blunt tool. But combined with the other parts of the sensor (PIR/microwave as mentioned above plus additional things: ambient light level, buzzer for notification, pixel ring, temp/pressure/humidity sensor, all of which I've already included in the design), audio sensing will make a nice addition.
So yes it requires a small electret mic as it has to fit in a small case mounted on the ceiling. My ideal spec for this audio sensor would be to be able to simply trigger a digital output when someone in the room speaks or makes any noise less than "quiet room". I was also toying with the idea of having different outputs for different audio types:
any noise slightly louder than ambient room noise (including hum of fridge, etc.) - this needs remote threshold setting for each room
single clap
double clap
This would of course be even more useful, let's say if PIR/microwave movement detection AND audio detection were not triggered for eg 30 mins, lights go out, you could just clap to restore lighting again.
Likewise double clap to select next light scene, etc.
Hope the above makes sense
So in summary, I am not trying to find the best solution period, I am not trying to find an accurate or perfect solution, but I am trying to find the best solution given the constraints.
