I was thinking that I will have a lot more answer here cause there is not a lot of french and I know how to speak English , anyway, I think I have the issue , I use a variable that I had to itself but I never initialize it. I am pretty sure it will work.
Edit: it don't work the issue wasn't the non initialized variable
And finnaly here is the cleaned code:
#include <Servo.h>
// defines pins numbers
const int in1 = 2;
const int in2 = 3;
const int in3 = 4;
const int in4 = 5;
#define cp_1 18
#define cm_1 16
#define cp_2 19
#define cm_2 17
#define PI 3.141592
#define nb_pas 1120
#define r_roue 30.36
#define fc_gauche 21
#define fc_start 15
#define sw_team 14
#define fc_droite 20
#define pin_servo_droit 7
#define pin_servo_gauche 6
bool flag1 = false, flag2 = false;
double p_robot = 214;
float compensation = 300;
double P_roue = PI * 2 * r_roue; //Définition & Calcul du périmètre dz la roue
double P_tour = PI * p_robot; //Définition & Calcul du périmètre du robot
float theta_tick = 360 * P_roue / (P_tour * nb_pas); //Calcul la valeur du tick pour avoir parcourue 1rad
float dist_tick = P_roue / nb_pas; //Calcul la valeur du tick pour avoir parcourue 1mm*
double tck1, tck2, x_reel, y_reel, angle;
Servo s_gauche;
Servo s_droit;
void compteur1() {
if (!digitalRead(cm_1)) {
tck2--;
tck2++;
void compteur2() {
if (!digitalRead(cm_2)) {
tck1--;
tck1++;
s_droit.attach(pin_servo_gauche);
s_gauche.attach(pin_servo_droit);
// Sets the two pins as Outputs
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode(cp_1, INPUT_PULLUP);
pinMode(cp_2, INPUT_PULLUP);
attachInterrupt(digitalPinToInterrupt(cp_1), compteur1, FALLING);
attachInterrupt(digitalPinToInterrupt(cp_2), compteur2, RISING);
x_reel = 1250;
y_reel = 400;
angle = 90;
servo('p');
int state, lstate = digitalRead(fc_start);
bool flagstart = false;
//a loop just for debugging
while (true) {
if (state != lstate) {
flagstart = true;
lstate = state;
while (flagstart) {
avancer(200, 1000);delay(3000); avancer(200, -1000);delay(300);
//end of this loop
go_zone_bleu();
//pousser de palet
servo('o');
digitalWrite(in1, LOW);
analogWrite(in2, 90);
analogWrite(in3, 90);
digitalWrite(in4, LOW);
delay(2500);
// set du x
avancer(-75, 200);
servo('f');
// reset pos
servo('f');
while (!(flag1 && flag2)) {
if (!digitalRead(fc_gauche) && !flag1) {
analogWrite(in4, 100);
digitalWrite(in3, LOW);
analogWrite(in4, 0);
flag1 = true;
if (!digitalRead(fc_droite) && !flag2) {
digitalWrite(in2, LOW);
analogWrite(in1, 100);
flag2 = true;
analogWrite(in1, 0);
//set du y
avancer(500, 200);
flag1 = false;
flag2 = false;
flag1 = true;
flag2 = true;
avancer(200, 200);
avancer(480, 200);
Serial.println("3\n");
delay(3000);
avancer(-105, 300);
delay(3000);
avancer(-105, 300);
delay(3000);
delay(1000000);
//com with an other arduino
void grab(int x) {
switch (x) {
case 1:
Serial.print("h0000\n");
delay(3000);
Serial.println("0\n");
Serial.print("h2000\n");
delay(3000);
case 2:
Serial.print("h0400\n");
delay(1300);
Serial.print("h1200\n");
delay(2500);
case 3:
Serial.print("h0900\n");
delay(3000);
delay(800);
delay(3000);
void releas(int x) {
switch (x) {
case 1:
delay(3000);
Serial.println("1\n");
delay(100);
Serial.print("h1500\n");
delay(2000);
case 2:
Serial.print("h0500\n");
delay(1500);
Serial.print("h1999\n");
delay(3000);
case 3:
Serial.print("h1000\n");
delay(3000);
delay(3000);
void go_zone_bleu() {
servo('p');
deplacement(1250, 790, 170);
deplacement(1880, 790, 170);
deplacement(2040, 290, 170);
deplacement(2600, 290, 200);
servo('o');
void servo(char x) {
switch (x) {
case 'f':
s_gauche.write(360);
s_droit.write(0);
Serial.println("fermer");
case 'o':
s_gauche.write(0);
s_droit.write(360);
Serial.println("ouvert");
case 'p':
s_gauche.write(50);
s_droit.write(150);
Serial.println("pousser");
default:
void deplacement(int x, int y, int vitesse) {
double a = x - x_reel, b = y - y_reel, c = sqrt(a * a + b * b);
double angle_cible = atan(b / a) * 180 / PI, angle_d = 0;
x_reel = x;
y_reel = y;
if (a >= 0) {
if (b >= 0) {
angle_cible = angle_cible;
angle_d = angle_cible - angle;
angle = angle_cible;
angle_cible = 360 + angle_cible;
if (b >= 0) {
angle_cible = 180 + angle_cible;
angle_cible = 270 - angle_cible;
if (angle_d < -180) {
angle_d = angle_d + 360;
if (angle_d > 180) {
angle_d = angle_d - 360;
if (angle_d > 1 || angle_d < -1) {
tourner(150, angle_d);
avancer(c, vitesse);
void debug() {
Serial.println("reele:");
Serial.println(tck1);
Serial.println("erreur:");
Serial.println(abs(tck1) - abs(tck2));
void m_droite(char s, int vitesse) {
switch (s) {
case 'a':
analogWrite(in2, vitesse);
case 'r':
analogWrite(in1, vitesse);
case 's':
analogWrite(in1, LOW);
default:
void m_gauche(char s, int vitesse) {
switch (s) {
case 'a':
analogWrite(in3, vitesse);
case 'r':
analogWrite(in4, vitesse);
case 's':
analogWrite(in4, LOW);
default:
Commencez avec une valeur de Kp relativement élevée et Ki à zéro. Ensuite, ajustez Kp jusqu'à ce que le système réponde de manière stable à une entrée de référence.
Ensuite, ajustez Ki jusqu'à ce que l'erreur à long terme (offset) soit minimisée. Cependant, trop augmenter Ki peut causer une oscillation indésirable, donc il faut trouver un bon équilibre.
Si le système montre des oscillations indésirables, diminuez Kp et augmentez Ki. Si la réponse est trop lente, augmentez Kp et diminuez Ki.
Il est important de noter que les valeurs de Ki et Kp peuvent changer si le système est modifié, donc il faut réajuster régulièrement pour s'assurer des bonnes performances.
float calcule_vitesse(double pas, double pas_cible, int vitesse) {
double deceleration = -500 * pas / pas_cible + 880;
double acceleration = 500 * pas / pas_cible + 30;
return (min(min(acceleration, vitesse), min(deceleration, vitesse)));
void avancer(double v_max, int l) {
tck1 = 0;
tck2 = 0;
double vitesse_m1, vitesse_m2, vitesse;
double flag1 = false, flag2 = false;
l = l - 30;
double pas = l / dist_tick;
char sens;
double min_speed = v_max * 0.15, max_speed = v_max;
double correction=0, error, error_sum=0;
float Ki = 0.001, Kp = 1;
if (pas < 0) {
sens = 'r';
sens = 'a';
vitesse = calcule_vitesse(abs(tck1), abs(pas), v_max);
error = abs(tck2) - abs(tck1);
error_sum += error;
correction = Kp * error + Ki * error_sum;
//correction=max(-500,min(correction,500));
vitesse_m1 = vitesse + correction;
vitesse_m2 = vitesse - correction;
Serial.println(tck1-tck2);
vitesse_m1 = max(min_speed, min(max_speed, vitesse_m1));
vitesse_m2 = max(min_speed, min(max_speed, vitesse_m2));
//Serial.println(abs(tck2) - abs(tck1));
if (abs(tck1) < abs(pas)) {
m_gauche(sens, vitesse_m1);
flag1 = true;
m_gauche('s', 0);
if (abs(tck2) < abs(pas)) {
m_droite(sens, vitesse_m2);
flag2 = true;
m_droite('s', 0);
l = l + 30;
Serial.println("\n\n\npas theo");
Serial.println(pas);
Serial.println("pas réel");
Serial.println("erreur");
Serial.println("erreure de pos");
Serial.println(((double)abs(tck1) - (double)abs(pas)) / (double)abs(pas));
void tourner(int v_max, int angle) {
tck1 = 0;
tck2 = 0;
double pas = angle / theta_tick; //Calcul du nombre de tick pour tourné en fonction de l'angle voulu
char sens1, sens2;
double correction1, correction2, error, error_sum;
float Ki = 0.00, Kp = 5;
if (pas < 0) {
sens1 = 'a';
sens2 = 'r';
sens1 = 'r';
sens2 = 'a';
error_sum += error;
correction1 = Kp * error + Ki * error_sum;
correction2 = Kp * error + Ki * error_sum;
vitesse_m1 = vitesse + correction1;
vitesse_m2 = vitesse - correction2;
//Serial.println(vitesse);
m_gauche(sens1, vitesse_m1);
flag1 = true;
m_gauche('s', 0);
m_droite(sens2, vitesse_m2);
flag2 = true;
m_droite('s', 0);
