Debugging aid, you may find useful.
Tutorial
Every now and then I use the following technique to help in trouble shooting a sketch.
You might find this useful too or maybe have some suggestions that expand on its capability.
First things first, we must remember that adding debug code to a sketch will change timing and might make things not work.
Basic Idea
We have what I call a PSW (Process Status Word) which is printed to the serial monitor (or LCD) whenever the PSW changes.
- No changes, no printing.
A 16-bit representation of our PSW is displayed along with a two-line header to identify the bits.
We could use a 32-bit PSW if extra bits are needed.
The following sketch shows the toggling of pins 13 and 12 along with the current state of a switch on pin 8.
This could be used to monitor the state of a State Machine, Flags, analog limit events etc.
We must remember that the PSW is only printed when loop() starts so events that happen several times before a return to loop() will be missed.
Example, here we see pins 13 and 12 are HIGH and our switch is released (HIGH).
111111
5432109876543210
0011000100000000
// P S W
//Debugging with PSW (Process Status Word)
//Used to help diagnose coding problems.
//Whenever the PSW changes, the PSW bit fields are printed.
//We can use these bits to see the state of strategic variables which might help in our debugging.
//To set a bit use bitSet(XX, YY); and to reset a bit use bitClear(XX, YY),
//where XX is the variable and YY is the bit number to be modified.
// example:
// 111111
// 5432109876543210
// Assume PSW = B000000011111111
// set bit 11 bitSet(PSW, 11);
// PSW = B000100011111111
// clear bit 4 bitClear(PSW, 4);
// PSW = B000100011101111
#define DEBUG //comment this line to remove all debug code <-------<<<<<<
#ifdef DEBUG
#define SET(...) bitSet(PSW, __VA_ARGS__)
#define RESET(...) bitClear(PSW, __VA_ARGS__)
#define PSWupdate(...) modifyPSW(__VA_ARGS__)
#define PSWshow printPSW()
const byte numberOfBits = sizeof(int) * 8;
unsigned int PSW = 0;
unsigned int oldPSW = 0;
unsigned int PSWcounter = 0;
inline void printPSW()
if (oldPSW != PSW)
//update to the new value
oldPSW = PSW;
//print the binary value of our PSW
Serial.println(F("111111"));
Serial.print(F("5432109876543210 PSW# = "));
Serial.println(++PSWcounter);
//add leading 0s
for (byte i = 0; i < numberOfBits; i++)
char BIT = (PSW & (1 << (numberOfBits - 1 - i))) > 0 ? '1' : '0';
Serial.print(BIT);
Serial.println("\n");
void modifyPSW(byte BIT, byte state)
if (state == HIGH)
bitSet(PSW, BIT);
return;
bitClear(PSW, BIT);
} //END of updatePSW()
#else
#define SET(...)
#define RESET(...)
#define PSWshow
#endif
// G P I O & V a r i a b l e s
const byte heartbeatLED = 13; //+5V---[220R]---[LED]---PIN
const byte testLED = 12; //+5V---[220R]---[LED]---PIN
const byte mySwitch = 8; //+5V---[50k]---PIN---[Switch]---GND
//Timing stuff
unsigned long heartbeatLEDTime;
unsigned long testLedTime;
// s e t u p ( )
pinMode(heartbeatLED, OUTPUT);
pinMode(testLED, OUTPUT);
pinMode(mySwitch, INPUT_PULLUP);
} //END of setup()
// l o o p ( )
//during debug mode, print changes in PSW (Process Status Word)
PSWshow;
//**************************************** toggle heartbeatLED
if (millis() - heartbeatLEDTime >= 1000ul)
//restart this TIMER
heartbeatLEDTime = millis();
digitalWrite(heartbeatLED, !digitalRead(heartbeatLED));
//update PSW
PSWupdate(heartbeatLED, digitalRead(heartbeatLED));
//**************************************** toggle testLED
if (millis() - testLedTime >= 500ul)
testLedTime = millis();
digitalWrite(testLED, !digitalRead(testLED));
//update PSW
PSWupdate(testLED, digitalRead(testLED));
//**************************************** read mySwitch
//update PSW
PSWupdate(mySwitch, digitalRead(mySwitch));
delay(50); //just for testing
} //END of loop()
