ESP32 / ESP32-S2 / ESP32-S3 hardware debugging features and how to use them in your own sketches.
Our beloved ESP32/S2/S3 chips actually support hardware debugging features: two hardware code breakpoints and two hardware data breakpoints.
In Espressif terminology these are called IBREAK and DBREAK, and Espressif provides the following API:
esp_cpu_set_watchpoint()
esp_cpu_set_breakpoint()
esp_cpu_clear_watchpoint()
esp_cpu_clear_breakpoint()
And... thats pretty much where the documentation ends.
If you try setting a breakpoint or watchpoint, surprisingly it does trigger - but all you get is a register dump and:
Guru Meditation: exception was unhandled (DebugException)
That is not exactly what we want. Wed rather intercept it, take control, and do something useful - log the event, for example.
Or anything else.
Below is a sketch (Arduino framework, for simplicity) for ESP32, ESP32-S2 and ESP32-S3. The same thing could be done on RISC-V as well, but I was too lazy to implement it.
The sketch consists of two files which should be placed in the same directory.
What the sketch does:
It installs Watchpoint #0 on writes to a variable and then repeatedly writes to it while printing some stats.
(Watchpoint #1 was already eaten by FreeRTOS canaries.)
Displayed output includes:
a) number of watchpoint triggers
b) current protected variable value
c) address of the instruction that caused the trigger
The implementation details and caveats are explained in the comments.
Why I needed this:
I was logging accesses to WiFi registers (0x60033xxx) to capture initialization sequences and timing behavior.
Why someone else might care:
This is also an example of handling a high-priority interrupt while dispatching into a C handler. With minor modifications the code can be turned into a controlled single-step execution mechanism.
File di.ino:
// Example sketch showing how on ESP32, ESP32-S2 and ESP32-S3:
// 1. Set up memory write protection (a variable in this example) (see esp_cpu_set_watchpoint())
// 2. Skip an instruction (debug_exception_handler)
// 3. Handle a high-priority interrupt (di.S)
// A breakpoint can be set and intercepted in a similar way (see esp_cpu_set_breakpoint()).
// DBREAK and IBREAK can be combined for controlled single-step execution.
#include <Arduino.h>
// Exception Frame.
struct exc_frame {
uint32_t ps;
uint32_t pc; // pointer to the instruction that triggered the interrupt
uint32_t registers[20];
extern "C" void debug_exception_handler(struct exc_frame *frame);
// Interrupt trigger counter
static int triggered = 0;
// Address of the instruction that triggered the interrupt
static uintptr_t address = 0;
// DebugInterrupt handler. (Generated by the CPU when protected memory is accessed)
// Data watchpoints and code breakpoints arrive here, but in this example
// we only handle data watchpoints.
// Skips the instruction that triggered the interrupt and increments
// the event counter.
// Called from di.S, parameters are passed via stack.
void IRAM_ATTR debug_exception_handler(struct exc_frame *f) {
// Instruction length lookup table.
// Instruction length determined by its first byte.
// Length may vary from 2 to 4 bytes, including 3-byte instructions.
static const uint8_t xt_insn_len[] = { XCHAL_BYTE0_FORMAT_LENGTHS };
// PC register = address of the instruction that triggered the interrupt.
// Read the first instruction byte through IBUS. Harvard architecture after all.
// 1. IBUS requires aligned 32-bit access.
// 2. Xtensa instructions can be 2, 3, or 4 bytes long.
// Therefore we read an aligned word and then shift it.
// No other option — otherwise the CPU will hang.
// The first instruction byte (`opcode`) determines the instruction length.
uintptr_t pc = (uintptr_t)f->pc;
// Save the address of the instruction that triggered the interrupt
address = pc;
uint32_t aligned = pc & ~3;
uint32_t word = *(volatile uint32_t *)aligned;
uint32_t shift = (pc & 3) * 8;
uint8_t opcode = (word >> shift) & 255;
// Skip the instruction
f->pc = f->pc + xt_insn_len[opcode];
// Or this way, if we do not want to skip it:
// esp_cpu_clear_watchpoint(0);
// Increment the counter
triggered++;
// Test variable. This one will be protected.
// volatile so the compiler doesn't optimize it away
static volatile int test = 666;
// Enable protection using ESP-IDF:
// Watchpoint#0, variable test, length = 4 bytes
// Length may be from 1 to 64 bytes, but the address must be aligned
// to the protection size. For example, a 16-byte array must be aligned
// on a 16-byte boundary. __attribute__((aligned)) to the rescue.
// Watchpoint#1 is already occupied by FreeRTOS and there are no others.
// There are only two hardware watchpoints available.
esp_cpu_set_watchpoint(0, (const void *)&test, 4 , ESP_CPU_WATCHPOINT_STORE);
// Write into protected memory:
// this should trigger an interrupt and invoke debug_exception_handler().
// The variable value will NOT change because our handler simply skips
// the instruction.
// The handler may re-execute the instruction — in that case there is no
// need to modify PC, but esp_cpu_clear_watchpoint(0) should be called.
// Otherwise, after re-executing the instruction, another interrupt will
// immediately be generated and so on forever.
test = triggered;
// A sketch without delay is not a sketch.
// Expected output (an example): "Triggered=321, test=666, address=4200xxxx"
Serial.printf("Triggered=%d, test=%d, address=%x\r\n", triggered, test, address);
File di.S:
// Intercept DebugInterrupt and call a handler written in C (Xtensa, windowed ABI)
// Interrupt handlers for levels 4, 5, 6 and 7 must be written in assembly.
// This is because the system does not invoke them like a regular C function.
// This file contains an assembly adapter that calls regular C code.
#ifdef __XTENSA__
#include <xtensa/coreasm.h>
#include <xtensa/corebits.h>
#include <xtensa/config/system.h>
#include "sdkconfig.h"
#include "xtensa_rtos.h"
#include "soc/soc.h"
#include "xt_asm_utils.h"
#include "xtensa_context.h"
#define CAUSE_DEBUGEXCEPTION (1)
#define XT_DEBUGCAUSE_DI (5)
#if (CONFIG_ESP32_ECO3_CACHE_LOCK_FIX && CONFIG_BTDM_CTRL_HLI)
// ESP32 v3.00 contains a hardware bug. We do not really care about the details,
// and honestly we do not fully understand them either.
// The code below contains two workaround snippets copied from xtensa_vectors.S
// (without the slightest understanding of how they actually work).
# define BUGGY_CHIP
#endif
.section .iram1, "ax"
// User C function
.extern debug_exception_handler
.type debug_exception_handler, @function
// Weak symbol, may be overridden
.global xt_debugexception
.type xt_debugexception, @function
.align 4
.literal_position
.align 4
// DebugExceptionVector saves register A0 and jumps to xt_debugexception
// A0 is saved using:
// wsr a0, EXCSAVE+XCHAL_DEBUGLEVEL
// See xtensa_vectors.S:_DebugExceptionVector
xt_debugexception:
#ifdef BUGGY_CHIP
// The original workaround code contains a strange line.
// Commented it out just in case: A0 is already saved,
// no need to trash somebody else's stack.
// s32i a0, sp, XT_STK_EXIT
// Read bit 13 of CPU CoreID.
// If it is 0, we are running on core 0; otherwise on core 1.
rsr.prid a0
extui a0, a0, 13, 1
// Try to determine whether this interrupt came from BT
// or whether this is a regular DebugInterrupt.
// If we think BT caused it, execute some magical delay.
// No idea why. Espressif does this in their code,
// so let's not argue.
#if (CONFIG_BTDM_CTRL_PINNED_TO_CORE == PRO_CPU_NUM)
beqz a0, 1f
#else
bnez a0, 1f
#endif
rsr a0, DEBUGCAUSE
extui a0, a0, XT_DEBUGCAUSE_DI, 1
bnez a0, debug_di_exc
1:
#endif // BUGGY_CHIP
// Set exception code in EXCCAUSE just in case.
movi a0, CAUSE_DEBUGEXCEPTION
wsr a0, EXCCAUSE
// This trampoline code is based on the GDBStub trampoline.
// It should be rewritten eventually: there is no reason to copy
// everything into Level1.
// The code should simply use Level6 everywhere.
// For now...
// Copy EPC and EXCSAVE from DEBUGLEVEL (Level6)
// into EXCEPTIONLEVEL (Level1).
rsr a0,(EPC + XCHAL_DEBUGLEVEL)
wsr a0,EPC_1
// Restore our A0 saved by _DebugExceptionVector
// and also save it into Level1.
rsr a0,(EXCSAVE + XCHAL_DEBUGLEVEL)
wsr a0,EXCSAVE_1
// Build trampoline
// Interrupt levels 4,5,6 and 7 are high-priority interrupts,
// therefore handlers must be written in assembly.
// Since writing EVERYTHING in assembly sounds unpleasant,
// set up an environment allowing us to call a C function.
// Allocate stack space for exception frame.
// Pointer to this frame will be passed to the C handler.
// The C code may modify the frame contents
// (for example change PC).
addi sp, sp, -XT_STK_FRMSZ
// Start saving context
// Save A0 (return address)
s32i a0, sp, XT_STK_A0
// Save Processor State
rsr a0, PS
s32i a0, sp, XT_STK_PS
// Save PC
// PC was copied into Level1 above,
// therefore EPC_1 instead of EPC_6
rsr a0, EPC_1
s32i a0, sp, XT_STK_PC
// Save standard context
call0 _xt_context_save
// Save SP
addi a7, sp, XT_STK_FRMSZ
s32i a7, sp, XT_STK_A1
// _xt_context_save() does not save A12 and A13.
// Have to do it manually :(
s32i a12, sp, XT_STK_A12
s32i a13, sp, XT_STK_A13
// Save EXCCAUSE and VADDR.
// Not really needed, but keep them for completeness.
rsr a0, EXCCAUSE
s32i a0, sp, XT_STK_EXCCAUSE
rsr a0, EXCVADDR
s32i a0, sp, XT_STK_EXCVADDR
rsr a0, EXCSAVE_1 // remove this line later
// Configure PS before calling C:
// Clear EXCM and disable level1...level5 interrupts
// (everything except NMI and DEBUGINTERRUPT).
movi a0, PS_INTLEVEL(5) | PS_UM | PS_WOE
wsr a0, PS
// Save PC.
// This value will be available from C as frame->pc.
// It may be modified and execution will continue
// at the new PC after handler exit.
// Pass stack pointer to handler.
// Stack already contains the exception frame.
// After callx4 register A6 becomes A2
// (first function argument).
mov a6, sp
rsr a9, EPS_6
s32i a9, sp, XT_STK_PS
// Finally. Call C handler.
movi a11, debug_exception_handler
callx4 a11
// Restore EPC_6 from exception frame->pc
l32i a0, sp, XT_STK_PC
wsr a0,(EPC + XCHAL_DEBUGLEVEL)
// Restore everything and return.
// Execution resumes from EPC_6.
call0 _xt_context_restore
l32i a12, sp, XT_STK_A12
l32i a13, sp, XT_STK_A13
// Return address (A0)
l32i a0, sp, XT_STK_EXIT
// Stack (A1==SP)
addi sp, sp, XT_STK_FRMSZ
rfi XCHAL_DEBUGLEVEL
#ifdef BUGGY_CHIP
.align 4
debug_di_exc:
// Just a delay
movi a0, 243
2:
addi a0, a0, -1
.rept 4
nop
.endr
bnez a0, 2b
// Restore return address (A0) and return
rsr a0, EXCSAVE+XCHAL_DEBUGLEVEL
// Mandatory lines below.
// Without them the linker will not pull this file
// into the project.
.global ld_include_xt_debugexception
ld_include_xt_debugexception:
#endif // __XTENSA__
Hope someone can find it useful!
