Hi everyone,
I'm trying to do something very simple: I'm trying to get a DateTime object and cast it into a String!
I expected that this would take me 2 minutes to do, but it's currently taken me 30 minutes!
The code is really simple:
DateTime now = rtc.now();
String str = String(now.year(), DEC) + '/' + String(now.month(), DEC) + '/' + String(now.day(), DEC) + " " + String(now.hour(), DEC) + ':' + String(now.minute(), DEC) + ':' + String(now.second(), DEC);
SerialTransmit("$RTC: " + str);
The output I expect is: "$RTC: 2017/12/01 13:13:55".
The output I receive is: "$RTC: 22165/165/165 165:165:85".
Does anyone know what is going on here?
J-M-L
December 1, 2017, 1:29pm
2
if you print str to the console, what do you see?
what is SerialTransmit?
does addition overload support (const char *) + (String) ?
Don't use the String class at all would be the best advice
If you print now.month() to the serial console, what do you see?
J-M-L:
If I print str to serial, I get: 2165/165/165 165:165:85
SerialTransmit is a wrapper method for Serial.println.
I assume it does support as there is no compiler error? I'm not 100% sure though.
J-M-L
December 1, 2017, 1:51pm
5
then fix this first (seems your RTC is not handled properly)
if you print now.year() - what do you get?
if you print String(now.year()) - what do you get?
if you print String(now.year(),DEC) - what do you get?
When a pump isn't dispensing water, always look at the intake.
J-M-L:
I get junk, junk and more junk.
The strange thing is that I only tested this this on the Nano this morning and it was fine...
The problem is with the ESP32. The library doesn't seem to work with it.
For some reason, I assumed that the RTC library would work on ESP32.
Or your connections aren't right, since you now have a different hardware configuration...
J-M-L
December 1, 2017, 3:00pm
9
which RTC lib? and indeed which connexions? (and what voltage)
antonyc
December 1, 2017, 3:02pm
10
aarg:
SCL > SCL
SDA > SDA
VCC > 3.3v (5v doesn't work either)
GND > GND
Connections seem sound.
Load an I2C scan sketch and look for something on address 68 (DS3231).
antonyc
December 1, 2017, 4:49pm
13
aarg:
Hey! Thanks for your help. In the end, I just used NTP.
Just for anyone having similar problems, I had exactly the same issue and for me it turned out that the my breadboard wires were a little loose and not making contact properly. Turns out that the library still churns out these weird dates when you connect to a non-existent I2C address.
