About grounding
Hi all,
I'm still in the process of learning more about electronics and my knowledge is still very basic.
I have a relatively simple prototype on a breadboard consisting of three lights, a piezo, a push button and a MPC9700 temperature sensor.
Depending on how I do my grounding, I am getting very accurate readings from the MPC9700 or totally wrong ones.
If I put the sensor on its own +3.3V directly from the Arduino pin and ground it directly in the Arduino pin on one side, and the LEDs, button and piezo on a common GND while feeding the pull up for the button directly from the Arduino's +5V then I am getting accurate readings. But as soon as I start using the power rails on my breadboard or use the same +5V for both the pull up resistors attached to the push button and the sensor or use a common ground for everything on the project; the readings are off but about 0.3—0.5V soaring to 1.10+V (for an expected reading of around 0.75V).
I am obviously missing something here, but what? Can someone explain what is happening?
Thanks a lot!
--edit: Current schematics with accurate readings (click to enlarge):
i think those "grounds" on the breadboard are not connected together... I think each group of 10 (or maybe 5) is isolated from the others. You can check that with an ohmmeter (multimeter) or just add jumpers to make-sure all of the grounds are connected.
if thats a standard BreadBoard . and the jumpers are as indicated, that complete rail is currently grounded. What Transistor is that ?
Or is that a Temp Sensor ?
also i just noticed that u have the 3.3v connected directly to the 5v
DVDdoug:
I just checked with a multimeter and they are. On the breadboard I am using, the rails are split in two in the middle but otherwise, the 5 holes blocks are connected together on each halves.
woody_unreal:
Yes, my bad, this was an error in the Fritzing schematics.
Here is the updated version:
woody_unreal:
It's a MCP9700 temperature sensor
:slight_smile: now if you have the image is at is EXACTLY then u only have 1 wire to your sensor :slight_smile:
GRRRRRR I have trouble with Fritzing, let me fix that:
Since ive never used that sensor before but i looked at the datasheet is seems no resistor required .. Example
Imgur
so unless there is something odd in the coding :slight_smile:
also temperature – Starter Kit
I opened another thread about this sensor a few days ago and we determined that it was the best to do to filter out any interference as per Fig3 of the datasheet (cf http://www.ti.com/general/docs/lit/getliterature.tsp?genericPartNumber=lm35&reg=en&fileType=pdf)
I am using a 10k? resistor and a 1µF capacitor between the Vout and GND
i still think your breadboard should have been stable ,, regardless of the extras, since you said
so a off the wall thought , wonder if a wire in the board isn't connected or if a wire is making contact with the base of the breadboard, I wish i had a sensor around to try it like yours :slight_smile: also you can use the full 5v for that sensor.
are you using a copyed coding from someone else ?
so what happens if they all connect to a common ground, but you power the pushbotton and the sensor individually? i.e. connect the temperature sensor to a digital pin for +5v?
If you have the bushbotton and the temp. sensor in parallel they are bound to interact somehow... (but that's just my intuition - I had a problem similar to that at some point and since then try to power sensors individually cause I now it will work that way. If I don't do it, I always have that slight uncertainty that something might be interacting...)
woody_unreal:
No it's my own code on which someone suggested modifications for on this thread: http://arduino.cc/forum/index.php/topic,97012.0.html
I know the code is messy, sorry about that, I intend to clean it up when I get everything in order
fkeel:
This results in the sensor returning between 0.5V and 0.6V more than it should
what do you base your "what it should be" values on? I don't know the sensor you are using, but I would expect it to give higher readings when powered by 5v than when powered by 3.3v
if you are powering it through the digital pin and connecting it to a common ground and have no other connections going on... there really is nothing which should be interfering with your readings...
fkeel:
The datasheet says it will output 10mV/ºC no matter what voltage it is fed, as long as it is within specs. I removed the resistor and the capacitor and the sensor reads between 22.80 and 24.26ºC. Not sure why there is such a difference.
Without the resistor and capacitor, I can use the +5V rail but not the GND rail. If I feed the rail with +3.3V, readings are off coming in at around 30ºC.
Boy, is this frustrating!!!
ok :slight_smile: one thing also with your setup tha u need resistor to ground and to pin then resistor to sensor - you are seting it up with resistor to cap. and also the cap goes between the legs of the sensor- as indicated on the link for the other thread :slight_smile: the resistor to ground with get rid of those crazy values i bet
Yes I re-read the topic and it seems the person who was giving me advice was using the LM35 datasheet... Hence the confusion. I will try this when I get back today and report back :slight_smile:
