hello, i am begining my jurney on arduino with a fun EEG project, using star wars force trainer 2 toy. tho i seem to run into a few errors, problems where i thought you might be able to help. I can only get the data to show if i listen on 57600 serial, however the serial monitor still gives me errors such as ERROR: checksum and ERROR: packet too long 133. This is the code:
// Arduino Brain Library - Brain Serial Test
// Description: Grabs brain data from the serial RX pin and sends CSV out over the TX pin (Half duplex.)
// More info: https://github.com/kitschpatrol/Arduino-Brain-Library
// Author: Eric Mika, 2010 revised in 2014
#include <Brain.h>
// Set up the brain parser, pass it the hardware serial object you want to listen on.
Brain brain(Serial);
// Start the hardware serial.
Serial.begin(57600);
// Expect packets about once per second.
// The .readCSV() function returns a string (well, char*) listing the most recent brain data, in the following format:
// "signal strength, attention, meditation, delta, theta, low alpha, high alpha, low beta, high beta, low gamma, high gamma"
if (brain.update()) {
Serial.println(brain.readErrors());
Serial.println(brain.readCSV());
