#include "IRremote.h"
int power=0;
/-----( Declare Constants )-----/
int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11
/-----( Declare objects )-----/
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results; // create instance of 'decode_results'
/-----( Declare Variables )-----/
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
Serial.println("IR Receiver Raw Data + Button Decode Test");
irrecv.enableIRIn(); // Start the receiver
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
if (irrecv.decode(&results)) // have we received an IR signal?
// Serial.println(results.value, HEX); UN Comment to see raw values
translateIR();
irrecv.resume(); // receive the next value
// read the state of the pushbutton value:
switch(results.value)
case 0xE318261B:
if (power==0)
digitalWrite(ledPin,HIGH);
power=1;
else if (power ==1)
digitalWrite(ledPin,LOW);
power=0;
case 0x511DBB:
case 0x9716BE3F:
digitalWrite(ledPin, HIGH);
case 0x3D9AE3F7:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH)
// turn LED on:
delay(5);
// turn LED off:
digitalWrite(ledPin, LOW);
case 0x6182021B:
if (buttonState == HIGH) {
// turn LED on:
delay(7);
else {
// turn LED off:
void translateIR() // takes action based on IR code received
// describing Car MP3 IR codes
case 0xE318261B:
Serial.println(" power ");
case 0xF0C41643:
Serial.println(" zero ");
case 0x9716BE3F:
Serial.println(" one ");
case 0x3D9AE3F7:
Serial.println(" two ");
case 0x6182021B:
Serial.println(" three ");
case 0x8C22657B:
Serial.println(" four ");
case 0x488F3CBB:
Serial.println(" five ");
case 0x449E79F:
Serial.println(" six ");
case 0x32C6FDF7:
Serial.println(" seven ");
case 0x1BC0157B:
Serial.println(" eight ");
case 0x3EC3FC1B:
Serial.println(" nine ");
}//END translateIR
