I am working on a Heart rate measurement project where I am using AD8232 board from SparkFun this board is in Cardiac configuration and uses 3 electrodes at input (RA,LA and RLD). Here I want to use only two
electrodes, I know it's mandatory to use RA and LA electrode, where as RLD is used to reject 50-60Hz AC noise.
I thought connecting the RLD to RA and LA will help... But It's rejecting the main signal.
I wanted to be tricky here, I want to use any of the two electrodes (RA or LA) and use a filter circuit at RLD, Where the filter circuit should reject all other signal but only accepts 50-60Hz noise.
I have an idea how you can solve this. All you need is a Bandpass Filter. I prefer an active bandpass filter, but that is up to you. This link shows you how to create an bandpassfilter.
I have done some calcs on the first circuit on that page and these are my results:
The trouble with mains interference is that it is not just the fundamental, there are harmonics, so
you really want steep constant phase notch filters at the fundamental and low harmonics for best results, which is
a job for a digital filter.
