Access array in PROGMEM
This is just test code, just to learn. I have not used Arduino in a long time.
I loaded an array in PROGMEM to save on scratch-pad RAM.
Now, I want to see if I can walk through the array and read some elements.
In my code you can see if I hard code the array index pointers then I can access the data, other wise I can't. What am I missing?
Thank you in advance.
const char  atest2   [20][ 5]  PROGMEM  =
     {'0','Z','z'}    ,
     {'1','B','b'}    ,
     {'2','C','c'}    ,
     {'3','D','d'}    ,
     {'4','E','e'}    ,
     {'5','F','f'}    ,
     {'6','G','g'}    ,
     {'7','H','h'}    ,
     {'8','I','i'}    ,
     {'9','J','j'}    ,
byte nCounter  = 1 ;
char cTemp2 =  '.' ;
   Serial.begin( 56700 ) ;
   nCounter ++  ;
   //  this returns "2Cc"  correctly
   Serial.print(   atest2  [2][0]) ;
   Serial.print(   atest2  [2][1]) ;
   Serial.println( atest2  [2][2]) ;
   //this does not work correctly
   Serial.print(   atest2  [nCounter][0]) ;
   Serial.print(   atest2  [nCounter][1]) ;
   Serial.println( atest2  [nCounter][2]) ;
   delay(1000) ;
   if ( nCounter > 9 )
      nCounter = 0 ;
Look closely at the examples on the Arduino reference page (a very useful resource).
that's because compiler optimisation. the data in the array is constant and you have constant indexes, so the compiler just replace the array access by the value.
when you use a variable, the compiler can't optimize and because you did not use the right functions to read bytes, words etc from flash memory, it does not work
double check the doc pointed by @jremington
Yes:
// read back a char
  for (byte k = 0; k < strlen_P(signMessage); k++) {
    myChar = pgm_read_byte_near(signMessage + k);
    Serial.print(myChar);
works great for a single long chain of chars. I have an array of char arrays. Thats where I am getting held up. Its a two dimensional array that have.
I think I have it worked out: nesting the indexes was all it took. Thank you all!
this should work
const char testArray[][3] PROGMEM = {
  {'0', 'Z', 'z'},
  {'1', 'B', 'b'},
  {'2', 'C', 'c'},
  {'3', 'D', 'd'},
  {'4', 'E', 'e'},
  {'5', 'F', 'f'},
  {'6', 'G', 'g'},
  {'7', 'H', 'h'},
  {'8', 'I', 'i'},
  {'9', 'J', 'j'},
const byte nbRows = sizeof testArray / sizeof * testArray;
  Serial.begin(115200) ;
  Serial.print("nb rows = "); Serial.println(nbRows);
  for (byte i = 0; i < nbRows; i++) {
    for (byte j = 0; j < 3; j++) {
      char data = pgm_read_byte(&(testArray[i][j]));
      Serial.print(data);
      Serial.write(' ');
void loop() {}
Yes, I think that is why the "address of" operator(&) is required here
Or with your original program
Serial.print((char)pgm_read_byte(&atest2[nCounter][0])) ;
yes or really go do the maths to find the exact flash address
      char data = pgm_read_byte((uint16_t) testArray + 3 * i + j);
Or just use the "old fashioned way" of one dimensional arrays :wink:
const byte Rows = 10;
const byte Cols = 3;
const char testArray[Rows * Cols] PROGMEM = {
  '0', 'Z', 'z',
  '1', 'B', 'b',
  '2', 'C', 'c',
  '3', 'D', 'd',
  '4', 'E', 'e',
  '5', 'F', 'f',
  '6', 'G', 'g',
  '7', 'H', 'h',
  '8', 'I', 'i',
  '9', 'J', 'j',
  for (byte r = 0; r < Rows; r++) {
    for (byte c = 0; c < Cols; c++) {
      char data = pgm_read_byte(testArray + c + r * Cols);
      Serial.print(data);
      Serial.write(' ');
void loop() {}
Though it works, I must admit I like your solution more :wink:
yes and you can let the compiler compute the size of the array, as long as you fix one dimension for the math later on
const char testArray[] PROGMEM = {
  '0', 'Z', 'z',
  '1', 'B', 'b',
  '2', 'C', 'c',
  '3', 'D', 'd',
  '4', 'E', 'e',
  '5', 'F', 'f',
  '6', 'G', 'g',
  '7', 'H', 'h',
  '8', 'I', 'i',
  '9', 'J', 'j',
const byte Rows = sizeof testArray / Cols ;
