AD8232 sensor raw output vs serial monitor data (0-1024)
I am using Ad8232 sensor and we get the data As (0-1024) values on the serial monitor screen of the Arduino,
and I would like kindly to know what is the correlation between this output (0-1024) and the raw data that comes out of the sensor (in milli or micro volt )
Here I attached the data sheet and the code
Waiting for your kind answer
oid setup() {
// initialize the serial communication:
pinMode(10, INPUT); // Setup for leads off detection LO +
pinMode(11, INPUT); // Setup for leads off detection LO -
if((digitalRead(10) == 1)||(digitalRead(11) == 1)){
Serial.println('!');
else{
// send the value of analog input 0:
Serial.println(analogRead(A0));
//Wait for a bit to keep serial data from saturating
delay(17);
http://www.analog.com/media/en/technical-documentation/data-sheets/AD8232.pdf
//Power Supply 3.3v
//OUTPUT Output Signal A0
Do you have a link to the datasheet?
hi robtillaart,
Thank you for your kind response the datasheet is attached here
thank you again
Think you need to read - AD8232 Heart Rate Monitor Hookup Guide - SparkFun Learn
Thank you again Rob,
I have read and asked the company but no body helped me to know the exact propational between serial monitor values and the real sensed values
Here I attached the company support answer
The values you see in the serial monitor are proportional to the input voltage that’s being sensed, but there isn’t a conversion from the displayed value to voltage.
