Adafruit data logger shield RTC on Mega 2560
Hello,
I am using the Adafruit data logger shield but have trouble getting the RTC to work. All works fine on an UNO, on the Mega I can read and write the SD card but the RTC always gives me an error if I check of it is running:
rtc.begin();
if (! rtc.isrunning()) {
Serial.println(F("RTC is NOT running!"));
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(DATE), F(TIME)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call: rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
always gives "RTC is NOT running"
I followed the instruction on Older Datalogger Shield Leonardo & Mega Library | Adafruit Data Logger Shield | Adafruit Learning System.
I found some discussion on the Deek-Robot SD/RTC datalogging shield(V1.0), where you seem to need to jumper:
http://forum.arduino.cc/index.php?topic=279488.0:
I may have finally figured this out. Running jumpers for SDA/SCL from MEGA to Datalogging shield's pins on the header didn't work. But I did notice that there are also "holes" by the shields Power LED also market SDA & SCL. When I ran a set of jumpers there, I started getting the sketches to run properly. Hopefully others that run into this can avoid wasting the whole day like I did. I am posting a picture of the two cards and the connection to further illustrate this (later when I get more time).
However, I have an official Adafruit shield (new version) - do I need to make any modifications?
Thanks!
Henk
Very useful - thank you
hello, i'm facing a problem like you. can you post picture wiring mega and logger shield ? thankyou for your help
