Hello,
I'm trying to create a second SPI port to use with a Ethernet controller (W5500).
I'm following the tutorial on the Adafruit website:
For the multiplexing and pins selection I used the following diagram:
Feather M4 Pinout
It looks that SERCOM4 with A2(4:0), A3 (4:1) and D4(4:2) is available for use.
That will give the following test code:
#include <SPI.h>
#include "wiring_private.h" // pinPeripheral() function
// sercom miso sck mosi tx rx
SPIClass mySPI (&sercom4, 4, A3, A2, SPI_PAD_0_SCK_1, SERCOM_RX_PAD_2);
// do this first, for Reasons
mySPI.begin();
// Assign pins 4, A2, A3 to SERCOM functionality
pinPeripheral(4, PIO_SERCOM);
pinPeripheral(A3, PIO_SERCOM);
pinPeripheral(A2, PIO_SERCOM);
uint8_t i=0;
Serial.println(i);
mySPI.beginTransaction(SPISettings(8000000, MSBFIRST, SPI_MODE0));
mySPI.transfer(i++);
mySPI.endTransaction();
But nothing happens on all the pins if you measure it with a scope (10Mhz max). They all stay near GND level.
Is there something I'm doing wrong? I tried the same on SERCOM3 with pins 5,6 and 9. But also no result.
Thank you
