Adafruit IO time type conversion
Hello,
In other AIO sketches, the data->toLong() function would work just fine. However, in the time example, I unfortunately don't know how this type is different and why something like this won't work:
void handleSecs(char *data, uint16_t len) {
Serial.print("Seconds Feed: ");
Serial.println(data);
slt = data->toLong();
Getting this error: request for member 'toChar' in '* data', which is of non-class type 'char'
Looking to convert the time "data" to a long for use elsewhere in the program.
Any help would be greatly appreciated.
Aidan
This is the basic code I'm working with.
// Adafruit IO Time Topic Subscription Example
// Adafruit invests time and resources providing this open source code.
// Please support Adafruit and open source hardware by purchasing
// products from Adafruit!
// Written by Adam Bachman, Brent Rubell for Adafruit Industries
// Copyright (c) 2018 Adafruit Industries
// Licensed under the MIT license.
// All text above must be included in any redistribution.
/************************** Configuration ***********************************/
// edit the config.h tab and enter your Adafruit IO credentials
// and any additional configuration needed for WiFi, cellular,
// or ethernet clients.
#include "config.h"
/************************ Example Starts Here *******************************/
// set up the 'time/seconds' topic
AdafruitIO_Time *seconds = io.time(AIO_TIME_SECONDS);
// set up the 'time/milliseconds' topic
AdafruitIO_Time *msecs = io.time(AIO_TIME_MILLIS);
// set up the 'time/ISO-8601' topic
AdafruitIO_Time *iso = io.time(AIO_TIME_ISO);
// start the serial connection
// wait for serial monitor to open
while(! Serial);
Serial.print("Connecting to Adafruit IO");
// start MQTT connection to io.adafruit.com
io.connect();
// attach message handler for the seconds feed
seconds->onMessage(handleSecs);
// attach a message handler for the msecs feed
msecs->onMessage(handleMillis);
// attach a message handler for the ISO feed
iso->onMessage(handleISO);
// wait for an MQTT connection
// NOTE: when blending the HTTP and MQTT API, always use the mqttStatus
// method to check on MQTT connection status specifically
while(io.mqttStatus() < AIO_CONNECTED) {
Serial.print(".");
// we are connected
Serial.println(io.statusText());
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
// Because this sketch isn't publishing, we don't need
// a delay() in the main program loop.
// message handler for the seconds feed
// message handler for the milliseconds feed
void handleMillis(char *data, uint16_t len) {
Serial.print("Millis Feed: ");
// message handler for the ISO-8601 feed
void handleISO(char *data, uint16_t len) {
Serial.print("ISO Feed: ");
use code tags
Your code is hard to read, if you read the forum guidelines you would know about code tags and posted accordingly.
Aidan
This is the basic AIO time example I am working off of.
#include "config.h"
while(! Serial);
// start MQTT connection to [io.adafruit.com](http://io.adafruit.com)
io.connect();
Serial.print(".");
// we are connected
// [io.adafruit.com](http://io.adafruit.com), and processes any incoming data.
io.run();
If slt is suitably declared, try
slt = atol(data);
This will work if "data" is a zero-terminated character array (a C-string).
