Adafruit motor shield with IR remote
Hello everybody,
I would need your help to figure it out how to make things work.
I would like to simply drive 4 dc motors with an IR remote. I'm using the Adafruit motor shield but this is what happen:
When the command irrecv.enableIRIn() starts M1 and M2 output dont work anymore. I still can get voltage on M3 and M4 but nothing on the others.
I would like to know if there's a way to fix this or you suggest to change to another shield. In this case which would you suggest?
Thank you a lot for your time!
I expect it's a problem in your code or the components you're using or the way you have things connected or powered. But you have provided no information about any of those things which makes it difficult to help.
Steve
Hi, thank you for your reply.
Here's the code I'm using.
I've set the motor*.run(FORWARD); in the setup to test.
If I delete the irrecv.enableIRIn(); command everthing works ok (no matter the pin of the receiver).
Thank you all.
Programma per comandare Lux
Scritto da Francesco Trasimeni
#include <AFMotor.h>
#include "IRremote.h"
AF_DCMotor motor1 (1);
AF_DCMotor motor2 (2);
AF_DCMotor motor3 (3);
AF_DCMotor motor4 (4);
IRrecv irrecv(9);   //create instance of 'IRrecv'
decode_results results;    //create instance of 'decode_results'
long previous;
unsigned long LastReceive = 0;
unsigned long   TimerUp;   //UP arrow on the remote
boolean         TimerUpFlag = false;
unsigned long   TimerDown; //DOWN arrow on the remote
boolean         TimerDownFlag = false;
unsigned long TimerIntensity;
unsigned long TimerIncDec;
boolean intesityUpFlag   = false;
boolean intesityDownFlag = false;
int brightness;
unsigned long   dummy;
unsigned long * TimerPtr = &dummy; //pointer to the current timer
// Imposta i pin di controllo del L298N Dual H-Bridge Motor Controller
//______________________________________________________________________________________________
  irrecv.enableIRIn(); //start receive
motor1.setSpeed(255);
motor2.setSpeed(255);
motor3.setSpeed(100);
motor4.setSpeed(100);
  motor1.run(FORWARD);
  motor2.run(FORWARD);
  motor3.run(FORWARD);
  motor4.run(FORWARD);
  if (irrecv.decode(&results)) //is there IR remote button code
    Serial.println(results.value, HEX);
    processButton(); //process button press
    irrecv.resume(); //restart for next button press
  //**********************                                //Turn off upLED
  //if timing is enabled, is it time to stop
  if (TimerUpFlag && millis() - TimerUp >= 250ul)
    TimerUpFlag = false; //disable timing
    TimerPtr = &dummy;   //pointer to dummy timer
    fermo();
  //**********************                                //Turn off downLED
  if (TimerDownFlag && millis() - TimerDown >= 250ul)
    TimerDownFlag = false; //disable timing
    fermo();
void zpositivo()  {
void znegativo()  {
motor1.run(BACKWARD);
motor2.run(BACKWARD);
motor3.run(BACKWARD);
motor4.run(BACKWARD);
void xpositivo()  {
void xnegativo()  {
void ypositivo()  {
void ynegativo()  {
void fermo()  {
motor1.run(RELEASE);
motor2.run(RELEASE);
motor3.run(RELEASE);
motor4.run(RELEASE);
void processButton()
  switch (results.value)
    case 0xFFA857:                                           //UP Arrow
        Serial.println("Z+");
        TimerPtr = &TimerUp;  //point to this timer
        TimerUpFlag = true;   //enable timing
        zpositivo();
        TimerUp = millis();
    case 0xFFE01F:                                           //UP Arrow
        Serial.println("Z-");
        znegativo();
        TimerUp = millis();
    case 0xFF5AA5:                                           //UP Arrow
        Serial.println("X-");
        xpositivo();
        TimerUp = millis();
     case 0xFF10EF:                                           //UP Arrow
        Serial.println("X+");
        xnegativo();
        TimerUp = millis();
     case 0xFF18E7:                                           //UP Arrow
        Serial.println("Y+");
        ypositivo();
        TimerUp = millis();
     case 0xFF4AB5:                                           //UP Arrow
        Serial.println("Y-");
        ynegativo();
        TimerUp = millis();
    case 0xFFFFFFFF: //Repeat code
        Serial.println("REPEAT");
        *TimerPtr = millis();       //reset the current timer
      default:
can anyone suggest me what motor shield use?
I would need to drive 4 motors with encoders and use an IR remote.
Thank you very much!
Maybe there's a way to solve with the code.
Is this possible?
I got the same problem, and managed to solve it. There is a conflict with the libraries you are using that causes them to try to use the same timer pin. The Adafruit motor shield library uses Timer0 and Timer2, while the IrMaster library also uses Timer2. To fix this, you need to go into the boarddefs.h file, and change the default Timer from Timer2 to Timer1.
#else
// Arduino Duemilanove, Diecimila, LilyPad, Mini, Fio, Nano, Uno etc
// ATmega48, ATmega88, ATmega168, ATmega328
#define IR_USE_TIMER1 // tx = pin 9
//#define IR_USE_TIMER2 // tx = pin 3
