Hey guys,
I am trying to get motor controlled using IR receiver. The problem I have right now is that the motor does not run in the current program but works fine when I am not using the IR receiver. I am guessing its some programming issue rather than the hardware.
Sorry for the late reply but yes, serial output does come. I have found out that the Motor's do not work on port 1 and 2 of the motor shield but 3 and 4 work fine. But can't really use both 3 and 4 since I have two motors and both at 1A (already burned one of the H bridges).
Upon further investigation, I have noticed that the motor does move (like for nano second) but doesn’t act the way its supposed to (only on ouputs 1 and 2). I think its some sort of timer issues.
Upon further investigation, I have noticed that the motor does move (like for nano second) but doesn't act the way its supposed to (only on ouputs 1 and 2). I think its some sort of timer issues.
Does the motor move like it is supposed to if you don't use the IR remote?
I was told that the IRemote library uses Timer 2 and the motors 1/2 output also use timer 2 so there is a conflict and can’t be resolved I am just going to piggyback two SN754410NE now with heatsink to run the two DC motors off outputs 3/4.
I run into the exact problem, but I need to use 3 DC motors. So is there absolutely no way to avoid this conflict? Can we hack the IR library so it use some other timer? I think most people's first project will be a IR remote control to drive a motor, so it's very disappointing to get everything working quickly only to find out you are hitting a wall. Hopefully the IR and the Motor shield guys can come together and resolve this conflict?
mcjohn113:
Hey guys,
I have the same problem, and I was able to solve it by just editing the header file IRremoteInt.h by uncommenting the timer I wanted to use and commented the default timer.
