I need to measure a voltage that may range from -12 to +12V, relative to ground.
I'm only interested in readings that are between -12V and 0V, though; if the voltage goes above 0 I don't care what the reading is.
From another thread I learnt you can measure negative voltages with a resistor divider, so this circuit:
... should let me read anything from -12V to +5V. That's all I need.
However, if the input voltage is higher than +5V, the voltage at the Arduino's input pin could go up to 7V. Do I need to protect the Arduino from this, or will its internal protection diodes be enough? We're talking about a maximum current of 0.1mA. Should I do this:
I'm guessing that if the verdict is yes to external diodes, I'll need to use Schottkys for their low voltage drop...
Thanks! h
