Hi guys,
I’m facing a problem with the Giga when I’m trying to sweep the DAC voltage from 0-1.7V, the ADC1,2 reading drifts slightly while it’s supposed to be constant. I’m using advanced analog library for fast 16bit ADCs and analogWrite for DAC. Here’s a graph:
Blue DAC output goes through a gain amplifier –> sma before oscilloscope, hence it ranges from 0 to 12V.
Do you guys think this is a mixed signal issue of the Giga hardware itself? Do you guys have any ideas of fixing this type of issue?
(This drift appears in my Serial Monitor, but not on the ADC pin itself. So, I’m certain that it’s the problem inside Giga, not my signal or PCB)
