nitrof
December 16, 2015, 1:31am
1
Hi.
I am building a library with a couple of snippets. many of them a inside one class. but I want to create a new class inside the same file for some other function. is it possible ???
#ifndef snippets_H
#define snippets_H
#if (ARDUINO >= 100)
#include "Arduino.h"
#else
#include "WProgram.h"
#endif
#include <SD.h>
class snippets {
public:
int funcDelay(int delay);
String intToOnOff(byte inInt);
String onOffBool(bool inBool);
String toString(const char* inchar);
bool stringToBool(const char* inChar);
byte onOffToInt( const char* input);
private:
class backup {
public:
backup();
void init();
void save(char* log);
private:
#endif
this code compile until I create an object of the second class
backup backup;
that sait backup doesn't name a type...
thanks
what happens when you include braces on your constructor...
class backup {
public:
backup();
void init();
like this:
class backup {
public:
backup(){};
void init();
you may not have the function defined outside the class (e.g. in an implementation *.cpp file).
compiles for me:
#include "snippets.h"
backup myBackup;
.h file:
#ifndef snippets_H
#define snippets_H
#else
#endif
//#include <SD.h>
class snippets{
public:
snippets();
private:
class backup{
public:
backup(){};
void init();
private:
#endif
I had to comment out the SD line, couldn't compile with it.
nitrof
December 16, 2015, 2:34am
6
hon... strange... just added capital to class name
Backup
and it is fix...
Delta_G:
Don't give your instance the same name as the class. That's bad too.
It is OK to the compiler, but it can be confusing to humans.
"OK to the compiler" means that you don't get any warnings even with -Wall -Wextra -pedantic.
