I have this program to move a stepper and servo and it works great. I want to add a button to start the program so it doesn't start automatically when I add power. What am I doing wrong here? Right now I'm getting an "unqualified id before { token" right above the delay(4000).
#include <Stepper.h>
#include <Servo.h>
int buttonPin;
const int stepsPerRevolution = 501; // steps to make 13 inch paracord lanyard
Servo myservo; // create servo object to control a servo
int pos = 20; // starting position is not top dead center
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 10, 9, 11);
buttonPin = 5;
pinMode(buttonPin, INPUT_PULLUP);
// set the speed at 60 rpm:
myStepper.setSpeed(60);
myservo.attach(7); // attaches the servo on pin 7 to the servo object
static boolean running = false;
int buttonState = digitalRead(buttonPin);
if (buttonState == HIGH)
running = true;
running = false;
delay(4000); //delay to let melted paracord cool before moving
myStepper.step(stepsPerRevolution);// step 2.5 revolutions in one direction:
delay(100);
for (pos = 120; pos <= 180; pos += 1) { // goes from 40 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(35); // waits 15ms for the servo to reach the position
for (pos = 180; pos >= 120; pos -= 1) { // goes from 180 degrees to 40 degrees
delay(5); // waits 15ms for the servo to reach the position
Do you actually want to read the button and set the "running" flag each time through loop()? (Not that it matters, since afaics you don't do anything with the flag anyway.)
And I think the button logic's upside down: you have the pullup turned on, so the pin will be high normally, and then low when pressed.
But if this:
... is your objective, it would be easier just to read the button in a while in setup() as below:
while (digitalRead(buttonPin) == HIGH) {}
Then it will sit in that while() until the button is pressed, then drop through into loop().
I did the auto format and it showed me the same brackets. If I remove the brackets, now it shows the "delay(100);" as "expected constructor..".
if (buttonState == LOW)
running = true;
running = false;
delay(100);
This works perfectly, but the button only stops the program. I want it to start the program also. Or add another button.
#include <Servo.h>
int buttonPin;
const int stepsPerRevolution = 200; // steps to make 13 inch paracord lanyard
buttonPin = 5;
if(digitalRead(buttonPin) == HIGH)// code runs runs until button is pressed
exit(0); // code stops when button is pressed
delay(4000);//delay to let melted paracord cool before moving
delay(100);
There is lots to find using the word toggle. Also you might want to look up state machines. Holding the state of something in a variable can be done in a simple way such as 0 for off and 1 for on.
Then you write a buttonPush function to detect button being pushed.
// by C Goulding aka groundFungus
const byte buttonPin = 2; // the pin to which the pushbutton is attached
const byte ledPin = 13; // the pin to which the LED is attached
bool buttonState = 0; // current state of the button
bool lastButtonState = 0; // previous state of the button
bool mode = false;
// initialize the button pin as a input with internal pullup enabled
// initialize the LED as an output:
pinMode(ledPin, OUTPUT);
// initialize serial communication:
Serial.println("Select (toggle) mode with push button");
static unsigned long timer = 0;
unsigned long interval = 50; // check switch 20 times per second
if (millis() - timer >= interval)
timer = millis();
// read the pushbutton input pin:
// compare the new buttonState to its previous state
if (buttonState != lastButtonState)
// if the current state is LOW then the button
// went from off to on:
digitalWrite(ledPin, !digitalRead(ledPin)); // toggle the output
mode = !mode; // toggle the state of the mode flag.
if (mode == true)
Serial.println("Manual mode\n");
Serial.println("Scan mode\n");
// save the current state as the last state,
//for next time through the loop
lastButtonState = buttonState;
Please post your latest code which reads a button press and toggles a state back and forth between run and stop and then gets the stepper to act according to the selected state.
#include <Servo.h>
const byte buttonPin = 5; // the pin to which the pushbutton is attached
bool mode = false;
timer = millis();
delay(100);
#include <Servo.h>
int buttonPin;
buttonPin = 5;
delay(100);
else{
exit(0);
I want the button to start and stop the program.
You have two different issues here.
Getting the program to start with a button press is very simple.
The stop routine is problematic given that you have blocking stepper and servo code which prevent the button from being read when the motors are running.
It's not clear how you want your process to proceed. Do you want to be able to stop only at the end of run after the servo has moved?
