Add PH sesnor code
Hello, I am making a green house by using Arduino mega. It include a LCD display, DHT sensor, light sensor and moisture sensor. Here is my code.
#include <Wire.h>
#include <dht.h>
LiquidCrystal_I2C LCD(0x3F,20,4);
#define dht_dpin 8
dht DHT;
int dht_dpin8;
int tempR;
int Fan=2;
int HeatFan=6;
const int sensorPin=A4;
int pump = 3;
int photocellPin = A5; //
int photocellVal = 0;
int LED1 = 7;
 LCD.init();
 LCD.backlight();
 pinMode(Fan,OUTPUT);
 pinMode(HeatFan,OUTPUT);
 pinMode(pump, OUTPUT);
 pinMode(sensorPin,INPUT);
 pinMode(LED1, OUTPUT);
 LCD.setCursor(0, 0);
 LCD.print("GreenHouse");
 LCD.setCursor(0, 1);
 LCD.print("Monitor Start");
 delay(3000);
 LCD.clear();
 DHT.read11(dht_dpin);
 tempR= DHT.temperature;
 LCD.setCursor(0,0);
 LCD.print("Temp:");
 LCD.print(DHT.temperature);
 LCD.print("C");
 LCD.setCursor(0,1);
 LCD.print("Humi:");
 LCD.print(DHT.humidity);
 LCD.print("%");
 delay(3000);
 if(tempR >= 26)
    digitalWrite(Fan,LOW);
    LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Temp High ");
     LCD.setCursor(0,1);
     LCD.print("Fan On ");
     delay(2000);
    digitalWrite(Fan,HIGH);
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Temp Nor ");
     LCD.setCursor(0,1);
     LCD.print("Fan Off ");
      delay(2000);
     if(tempR < 24)
    digitalWrite(HeatFan,LOW);
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Temp Low ");
     LCD.setCursor(0,1);
     LCD.print("HeatFan On ");
     delay(2000);
  else {
    digitalWrite(HeatFan,HIGH);
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     LCD.print("HeatFan Off ");
      delay(2000);
  int moist;
  moist = analogRead(sensorPin);
  Serial.println(moist);
  // 乾燥程度大於 700 時,亮燈
  if (moist > 700) {
     digitalWrite(pump, LOW);
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Soil Dry ");
     LCD.setCursor(0,1);
     LCD.print("Pump On ");
     delay(2000);}
  else {
      digitalWrite(pump, HIGH);
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Soil Nor ");
     LCD.setCursor(0,1);
     LCD.print("Pump Off ");
  delay(2000);
photocellVal = analogRead(photocellPin);
Serial.println(photocellVal);
delay(100);
if (photocellVal<1000)
digitalWrite(LED1,HIGH);
LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Light Nor ");
     LCD.setCursor(0,1);
     LCD.print("Light Off ");
     delay(2000);}
 else {
      digitalWrite(LED1, LOW);
      LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("Light Dim ");
     LCD.setCursor(0,1);
     LCD.print("Light On ");}
delay(2000);
This code is working. Then I want to add a PH senor. I use this code and it run normal.
#define SensorPin 0
unsigned long int avgValue;
float b;
int buf[10],temp;
int pump = 3;
int pump1 =4;
   LCD.init(); //初始化 LCD 模組
 LCD.backlight(); //設定 LCD 背光模式
  pinMode(SensorPin, INPUT);
  pinMode(pump1, OUTPUT);
  Serial.println("Ready");
 delay(3000);
 LCD.clear(); //
  for(int i=0;i<10;i++)       //Get 10 sample value from the sensor for smooth the value
    buf[i]=analogRead(SensorPin);
    delay(10);
  for(int i=0;i<9;i++)        //sort the analog from small to large
    for(int j=i+1;j<10;j++)
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
  for(int i=2;i<8;i++)                      //take the average value of 6 center sample
    avgValue+=buf[i];
  float phValue=(float)avgValue*5.0/1024/6; //convert the analog into millivolt
  phValue=3.5*phValue;                      //convert the millivolt into pH value
  Serial.print("    pH:");
  Serial.print(phValue,2);
  Serial.println(" ");
if (phValue > 11)
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("PH High ");
     LCD.setCursor(0,1);
     LCD.print("pump1 On ");
     delay(2000);}
     else {
       LCD.clear();
     LCD.setCursor(0,0);
     LCD.print("PH Nor ");
     LCD.setCursor(0,1);
     LCD.print("pump1 Off ");
      delay(2000);
 if (phValue < 10) {
     digitalWrite(pump1, LOW);
      LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     LCD.print("pump2 On ");
     delay(2000);}
     else {
      digitalWrite(pump1, HIGH);
      LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     LCD.print("pump2 Off ");
      delay(2000);
Then I put the second code into my first code. It run abnormal and show the following message.
"Arduino: 1.8.7 (Windows 10), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
111:142:1: error: expected unqualified-id before '{' token
exit status 1
option enabled in File -> Preferences."
Can anyone help me to fix this, thank you!!!
Here is my code combine two code in one.
#include <Wire.h>
#include <dht.h>
#define dht_dpin 8
dht DHT;
#define SensorPin 0
float b;
int buf[10],temp;
int pump2 = 3;
int pump1 =4;
int dht_dpin8;
int tempR;
int Fan=2;
int HeatFan=6;
int pump = 3;
int LED1 = 7;
 LCD.init();
 LCD.backlight();
  pinMode(pump2, OUTPUT);
 delay(3000);
 LCD.clear();
 LCD.setCursor(0,0);
 LCD.print("Temp:");
 LCD.print("C");
 LCD.setCursor(0,1);
 LCD.print("Humi:");
 LCD.print("%");
 delay(3000);
 if(tempR >= 26)
    LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     delay(2000);
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
      delay(2000);
     if(tempR < 24)
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     delay(2000);
  else {
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
      delay(2000);
  int moist;
  // 乾燥程度大於 700 時,亮燈
  if (moist > 700) {
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     delay(2000);}
  else {
     LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
  delay(2000);
delay(100);
LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
     delay(2000);}
 else {
      LCD.clear();
     LCD.setCursor(0,0);
     LCD.setCursor(0,1);
delay(2000);
    delay(10);
      if(buf[i]>buf[j])
        temp=buf[i];
        buf[i]=buf[j];
        buf[j]=temp;
  avgValue=0;
    avgValue+=buf[i];
if (phValue > 11)
     LCD.clear(); //顯示清除
     LCD.setCursor(0,0); //顯示至第 1 列第 1 個位置
     LCD.print("PH High ");// 在 LCD 顯示 Temp High
     LCD.setCursor(0,1); //顯示至第 2 列第 1 個位置
     LCD.print("pump1 On "); // 在 LCD 顯示 Fan On
     delay(2000);}
     else {
       LCD.clear(); //顯示清除
     LCD.print("PH Nor ");// 在 LCD 顯示 Temp Nor
     LCD.print("pump1 Off ");// 在 LCD 顯示 Fan Off
      delay(2000);
 if (phValue < 10) {
      LCD.clear(); //顯示清除
     LCD.print("pump2 On "); // 在 LCD 顯示 Fan On
     delay(2000);}
     else {
      LCD.clear(); //顯示清除
     LCD.print("pump2 Off ");// 在 LCD 顯示 Fan Off
      delay(2000);
If you put EVERY { on a line BY ITSELF, put EVERY } on a line BY ITSELF, and used Tools + Auto Format to correct your horrid indenting, you'd see what the problem is.
The code starting on line 143 is NOT in a function. All code MUST be in a function.
