I'm building a pick and place machine. I've attached a very bad schematic drawing, but basically:
- An Arduino Nano powered by host USB controls 3 Pololu A4988 stepper driver boards
- The chips of the Pololus are powered by the Arduino via host USB; the motors are powered by a 28V 8A power supply
- I've got a .1uf decoupling capacitor on each board and !SLP is tied to RST per Pololu's recommendation.
- There's small heat sinks on the A4988 chips.
- The steppers are rated for 1.7A each and I have the control pots of the Pololu boards dialed to 1/4 of capacity (2A rating)
Everything works for about 10 minutes, then the driver chips start overheating and resetting. Today I added a blower fan, powered by the 28V motor power supply, for more ventilation on the heat sinks.
But as soon as I plug it in the Arduino board resets, Windows plays the "USB device unplugged" sound, then I get a popup that the USB device is unrecognized. I can disconnect the fan and everything returns to normal, but I can never get the fan and the Arduino to run together.
Is this because the fan adds an inductive load so I need a diode? If so I have some 1N5817 1A diodes, will one of these work (or if not, what should I get) ? If this isn't the cause, can you tell me what else to look for or do?
Thanks as always.
