So I just let the smoke out of two Arduinos and strange things happening with a stepper driver?
So, I have been trying to build a motorised camera slide and I'm having a total nightmare!
Managed to get the code to run thanks to some really helpful members who got it working with the screen I had rather than the one in the project code.
Now it comes to the hardware, namely the stepper driver, I managed to blow up 2 Arduino mega boards trying to get this to work tonight. The first one blew the regulator when I plugged in the 12V supply to power the driver (I did all the wiring and blow another board the same way) So took another voltage regulator from a shield I never found a use for and managed to put that on one of the blown mega (very proud of myself) but I am not seeing this strange behaver, when I plug in over USB and connect the Stepper driver to 5V the Arduino shuts off, disconnect from 5V and it comes back on...So have I really messed up somewhere, or bad stepper driver? (if so that sucks as this is the only TMC2130 I have. got some TMC2209 but not the knowledge to change the code to use them) .
So really need some help here, as I'm off to poor a very stiff drink!
Imgur
Youre grounding your high power motor through your arduino
Youve got to run the high power lines around the arduino
But, I'm getting the 12V from the Arduino VIN, so would I not ground it on the Arduino too?
And I get the issue with the Arduino shutting down even when I don't have the 12v plugged into the stepper driver.
Use the 12v high power lines to power the motor driver directly, parallel to the arduino.
Power supply -> arduino
Power supply -> driver
Your arduino is over heating / smoking because youre plugged into the wall, and supplying 12v through the arduino vin pin and grounding thru the board as well.
Do you have a diagram with your power supply included?
It's just a wire from the Vin pin to the stepper driver, and the PSU is just a plugged 12V supply powring the Arduino via the barrel jack.
Look at this diagram, look how the 12v/gnd lines split. one goes to the arduino, and the other 12v/gnd lines goes around the arduino, direct to the driver board. I know its a different driver, but the power lines must be connected like this.
Absolutely not! All Arduino I/O pins are rated for max 5 volt, for some controllers only 3.3 volt.
It's from the Vin Pin, not an I/O pin the power is coming from the barrel jack that is powering the Arduino.
OK, will take the 12V directly from the 12v and GND lugs of the power jack. But, this still doesn't explain why the Arduino is shutting down when just the 5V is being plugged into the stepper driver, with no 12V connected anywhere.
Can you please post some images of your project?
So we can see your component layout.
Thanks.. Tom... :smiley: :+1: :coffee: :australia:
Just tore it down and order a new Arduino and stepper driver as I think it's beyond saving at this point.
But basically this is the issue
Imgur
Imgur
So, 12V powering aside, the Arduino dies when plugged into what is meant to be a 5V and GND pins seems like a big problem I'm not going to be able to fix without new hardware.
Okey. My interpretation of Your post was that You powered the load with 12 volt and tried to use an I/O pin low to make it run.
No. The copper strips on the board are not designed to carry motor currents.
What code are you trying to run?
Can you post your code?
Was just using the Blink code when debugging and working to narrow down the strage/regulator exploding behaviour (as I was thinking it was a hardware, not software issue).
I code I ultimately want to run is here (sorry it's quite long and I understand about 3% of it!):
#include "TimerOne.h"
#include <Encoder.h>
#include <stdint.h>
#define DEBUG
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_ILI9341.h>
#include <Adafruit_STMPE610.h>
//#include <TouchScreen.h>
#include <Adafruit_GFX.h>    // Core graphics library
//#include <Adafruit_TFTLCD.h> // Hardware-specific library
#include <Fonts/FreeSans9pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans12pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans18pt7b.h> // Hardware-specific library
#include <Fonts/FreeSans24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono24pt7b.h> // Hardware-specific library
#include <Fonts/FreeMono18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold18pt7b.h> // Hardware-specific library
#include <Fonts/FreeMonoBold24pt7b.h> // Hardware-specific library
//IM - Touch Screen presure
#define MINPRESSURE 10
#define MAXPRESSURE 10000
//IM - Define the limits of the touch screen
#define TS_MINX 150
#define TS_MINY 130
#define TS_MAXX 3800
#define TS_MAXY 4000
//IM - TRINAMIC 2130 STEPPER DRIVER
//#include <SPI.h> // SPI FOR SPI COMMS to the 2130 driver
#include <TMC2130Stepper.h>
#include <TMC2130Stepper_REGDEFS.h>
// For better pressure precision, we need to know the resistance
// between X+ and X- Use any multimeter to read it
// For the one we're using, its 300 ohms across the X plate
//TouchScreen ts = TouchScreen(XP, YP, XM, YM, 300);
// The control pins for the LCD can be assigned to any digital or
// analog pins...but we'll use the analog pins as this allows us to
// double up the pins with the touch screen (see the TFT paint example).
/*#define LCD_CS A3 // Chip Select goes to Analog 3
  #define LCD_CD A2 // Command/Data goes to Analog 2
  #define LCD_WR A1 // LCD Write goes to Analog 1
  #define LCD_RD A0 // LCD Read goes to Analog 0*/
#define LCD_RESET A4 // Can alternately just connect to Arduino's reset pin
// Assign human-readable names to some common 16-bit color values
// Modify these to match the colorspace of your LCD
#define  WHITE   0x0000 //
#define YELLOW    0x001F //
#define CYAN     0xF800 //
#define PURPLE  0x07E0 //
#define RED    0x07FF //
#define GREEN 0xF81F //
#define BLUE  0xFFE0 //
#define BLACK   0xFFFF //
#define PIN_BATTVOLT 15
#define STEPSMM 160
//IM - Pins for the Encoder with button. If the encoders running backwards swap enc0 and enc1 pins
#define PIN_BUTTON 19
#define PIN_ENC0 21 //encoder pin 1
#define PIN_ENC1 20 //encoder pin 2
//IM - Stepper Driver Enable Pin
#define PIN_ENABLE 40
#define PIN_DIR 42
#define PIN_STEP 41
#define PIN_CS 53
#define MOSI_PIN 51
#define MISO_PIN 50
#define SCK_PIN 52
//IM - Step and direction pin settings for the Stepper driver
#define MAX_SPEED  40 // In timer value
#define MIN_SPEED  1000
#define STALL_VALUE 5 // [-64..63]
#define DEBOUNCE 300
#define MINRUNTIME 10000
//number of battery voltage points
#define LOOKUP 20
#define STMPE_CS 8
Adafruit_STMPE610 ts = Adafruit_STMPE610(STMPE_CS);
#define TFT_CS 10
#define TFT_DC 9
Adafruit_ILI9341 tft = Adafruit_ILI9341(TFT_CS, TFT_DC);
//Adafruit_TFTLCD tft(LCD_CS, LCD_CD, LCD_WR, LCD_RD, LCD_RESET);
// If using the shield, all control and data lines are fixed, and
// a simpler declaration can optionally be used:
// Adafruit_TFTLCD tft;
long day = 86400000; // 86400000 milliseconds in a day
long hour = 3600000; // 3600000 milliseconds in an hour
long minute = 60000; // 60000 milliseconds in a minute
long second =  1000; // 1000 milliseconds in a second
//IM - Instansiate the encoder (on the rotary button) and tell it what pins we have used
Encoder myEnc(PIN_ENC1, PIN_ENC0);
//Config for the Trinamic 2130 set the pins pins
TMC2130Stepper driver = TMC2130Stepper(PIN_ENABLE, PIN_DIR, PIN_STEP, PIN_CS);
long oldPosition  = 0;
//long MaxSlide = 73235; //IM - Test value for max slide (aprox 1mtr)
long MaxSlide = 0; //IM - holds the maximum number of steps for the length of the slide rail. Its set during initialisation proccess.
long calSteps = 0; //IM - holds the value of steps whilst performing the calibration.
long RailLength = 0; //IM - holds the value for the lenght of the rail;
float StepsPerMM = 80.3; //IM - the number of steps on my stepper motor that cover 1mm of rail travel.
volatile long numruns = 0;
volatile long period = 10000;
volatile long carragePos = 0; //the absolute carrage position on the slider.
volatile unsigned long lastTriggered = 0;
long nextBattMillis = 0;
long runtime = 0;
long offset = 0;
long sspeed = 0;
long decimals = 0;
//IM - Defines the mid point of the touch screen, this will determin the direction of movment, buy pressing either side of this line.
int ts_MID = 195;
byte oldDays = 0;
byte oldHours = 0;
byte oldMinutes = 0;
byte oldSeconds = 0;
boolean buttonPressed = false; //Holds the value seeing if the button has been pressed by the user
boolean srunning = false;
boolean sdir = 0; //Bit Direction of travel of the motor
boolean oldsdir = !sdir; //Bit holding the last known Direction of travel of the motor
boolean needsInit = false;
boolean drawnStatusBlank = 1;
boolean drawnStatus = srunning;
boolean driverEnabled = false; //set the default to the stepper driver disabled.
boolean calibratedSlider = false; //sets true if the slider rail has been calibrated to the length.
boolean stall = false; //set the motor stall value to false.
boolean TMC2130enabled = false;
boolean carrageHomed = false; //has the carraged reached its home position (during calibration)
boolean lcdFlipped = false; //has the LCD been installed physically upsidedown?
boolean haltCarrage = false;
boolean countCarrage = true;
boolean carrageHalted = false;
boolean stallSleep = false; //some times we dont want to detect a motor stall, like right after it just happend.
int stallSleepDuration = 1000;
int calibrationStep = 0; //IM - stores the value of the calibrations step 1 - 3. 3 is fully calibrated and homed.
float rawVolt;
float volt;
int checkInerval = 50; //use as a delay to count down too.
void catchButton() {
  if (lastTriggered + DEBOUNCE < millis()) {
    buttonPressed = true;
    lastTriggered = millis();
    Serial.print("catchButton: Button Pressed");
//enable the stepper driver
void enableTMC2130() {
  Serial.println("enableTMC2130: stepper ENABLED");
  digitalWrite(PIN_ENABLE, LOW);
  TMC2130enabled = true;
//dissables the stepper driver
void disableTMC2130() {
  Serial.println("disableTMC2130: stepper dissabled");
  digitalWrite(PIN_ENABLE, HIGH);
//IM - VSense for Trinamic 2130
bool vsense;
//IM - RMS current for Trinamic 2130
uint16_t rms_current(uint8_t CS, float Rsense = 0.11) {
  return (float)(CS + 1) / 32.0 * (vsense ? 0.180 : 0.325) / (Rsense + 0.02) / 1.41421 * 1000;
//IM - Sets up the screen based on its physical mounted positon. Some screens may be mounted upsidedown for physical reasons
//this flips the image if required so the screen contents appear the right way up for the user. Other thigs get messed up when
//the screen is flipped round so we must account for that tool, setting the LCDFlipped bool helps track.
void SetScreenOrientation(bool flip) {
  if (flip) {
    tft.setRotation(3);
    lcdFlipped = true;
  else {
    tft.setRotation(1);
    lcdFlipped = false;
//##################################### SETUP #####################################
  tft.begin();
  if (!ts.begin()) {
    Serial.println("Unable to start touchscreen.");
  else {
    Serial.println("Touchscreen started.");
#ifdef DEBUG
  Serial.begin(250000);
  Serial.println(F("TFT LCD test"));
  Serial.print("TFT size is ");
  Serial.print(tft.width());
  Serial.print("x");
  Serial.println(tft.height());
#endif // DEBUG
  Serial.println("Setup Started");
  Serial.println("Instansiate TMC2130");
  //set TMC2130 config
  driver.begin();
  driver.rms_current(600); // mA
  driver.microsteps(16);
  driver.diag1_stall(1);
  driver.diag1_active_high(1);
  driver.coolstep_min_speed(0xFFFFF); // 20bit max
  driver.THIGH(0);
  driver.semin(5);
  driver.semax(2);
  driver.sedn(0b01);
  driver.sg_stall_value(STALL_VALUE);
  driver.stealthChop(1);
  Serial.println("Set stepper interrupt");
  // Set stepper interrupt
  cli();//stop interrupts
  TCCR1A = 0;// set entire TCCR1A register to 0
  TCCR1B = 0;// same for TCCR1B
  TCNT1  = 0;//initialize counter value to 0
  OCR1A = 256;// = (16*10^6) / (1*1024) - 1 (must be <65536)
  //turn on CTC mode
  TCCR1B |= (1 << WGM12);
  // Set CS11 bits for 8 prescaler
  TCCR1B |= (1 << CS11);// | (1 << CS10);
  // enable timer compare interrupt
  TIMSK1 |= (1 << OCIE1A);
  //sei();//allow interrupts
  //TMC2130 outputs on (LOW active)
  disableTMC2130();
  vsense = driver.vsense();
  //IM - SET THE STATE OF ALL THE PINS WE WILL BE USING
  //IM - Set the pins for the stepper driver
  //pinMode(PIN_STEP, OUTPUT); //step pin
  //pinMode(PIN_DIR, OUTPUT); //direction pin
  //pinMode(PIN_ENABLE, OUTPUT); //enable pin
  //IM - Set the initial pin states
  digitalWrite(PIN_BUTTON, HIGH); //IM - set the initial state of the button pin to high
  digitalWrite(PIN_ENABLE, LOW); //IM - set the initial state enable pin for the stepper driver
  /*tft.reset();
    uint16_t identifier = tft.readID();
    if (identifier == 0x9325) {
    #ifdef DEBUG
    Serial.println(F("Found ILI9325 LCD driver"));
    } else if (identifier == 0x9328) {
    Serial.println(F("Found ILI9328 LCD driver"));
    } else if (identifier == 0x7575) {
    Serial.println(F("Found HX8347G LCD driver"));
    } else if (identifier == 0x9341) {
    Serial.println(F("Found ILI9341 LCD driver"));
    } else if (identifier == 0x8357) {
    Serial.println(F("Found HX8357D LCD driver"));
    #endif // DEBUG
    #ifdef DEBUG
    /*Serial.print(F("Unknown LCD driver chip: "));
    Serial.println(identifier, HEX);
    Serial.print(F("I try use ILI9341 LCD driver "));
    Serial.println(F("If using the Adafruit 2.8\" TFT Arduino shield, the line:"));
    Serial.println(F("  #define USE_ADAFRUIT_SHIELD_PINOUT"));
    Serial.println(F("should appear in the library header (Adafruit_TFT.h)."));
    Serial.println(F("If using the breakout board, it should NOT be #defined!"));
    Serial.println(F("Also if using the breakout, double-check that all wiring"));
    Serial.println(F("matches the tutorial."));
    #endif // DEBUG
    identifier = 0x9341;*/
//tft.begin(identifier);
//main timer for the slider application
Timer1.initialize(period);         // initialize timer1, and set a 1/2 second period
//  Timer1.pwm(9, 512);                // setup pwm on pin 9, 50% duty cycle
Timer1.attachInterrupt(callback);  // attaches callback() as a timer overflow interrupt
Timer1.stop();
// IM - This is the interupt that will fire when the button is pressed
attachInterrupt(digitalPinToInterrupt(PIN_BUTTON), catchButton, FALLING);
//##################################### LCD ORIENTATION #####################################
//IM - Set the screen orientation. True is normal, False upsideown.
SetScreenOrientation(true);
tft.fillScreen(BLACK);
updateLCDTime(true);
updateLCDStatus();
rawVolt = ((float) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT) + analogRead(PIN_BATTVOLT)) / 5;
volt = toVolt(rawVolt);
//enable the stepper motor.
enableTMC2130();
//IM - Run the stepper motor.
//IM - this runs every half step
void callback()
  //IM - If the device has been calibrated we can check we dont hit the end of the rail
  if (calibratedSlider) {
    //Run the position as a half time
    if (countCarrage) {
      //if the direction is false then we are moving away from the home position towards MaxSlide
      if (sdir == true) {
        if (carragePos != MaxSlide) {
          //if it does then stop
          carragePos++;
        else {
          haltCarrage = true;
        //otherwise were heading for home watch out for 0
        if (carragePos != 0) {
          carragePos--;
          haltCarrage = true;
      countCarrage = false;
    //IM - Unless halt carrage is true run the slider
    if (!haltCarrage) {
      numruns++;
      digitalWrite(PIN_STEP, digitalRead(PIN_STEP) ^ 1);
      if (!carrageHalted) {
        Serial.println("############  Carratge halted! ############");
        //stopSlider();
        catchButton(); //IM - emulate the button being pressed.
        carrageHalted = true;
  } else //if its not calibrated we'll just hit the buffers.
    numruns++;
void stopSlider() {
  Serial.println("############  stopSlider! ############");
  srunning = 0;
  //disableTMC2130();
  Timer1.stop();
  updateLCDStatus();
//cDir is ture for left false for right. Unless the screen has been flipped
void carrageDirection(bool cDir) {
  if (cDir) {
    if (oldsdir != cDir) {
      digitalWrite(PIN_DIR, 0);
      sdir = true;
      Serial.print("#################################### Carrage Direction: ####################################");
      Serial.println(cDir);
      oldsdir = cDir;
      updateLcdDirection(cDir);
      digitalWrite(PIN_DIR, 1);
      sdir = false;
      oldsdir = cDir;
ISR(TIMER1_COMPA_vect) {
  PORTF |= 1 << 0;
  PORTF &= ~(1 << 0);
//##################################### LOOP #####################################
  //##################################### Check Endstop Initiailisation #####################################
  //if the unit has just been switched on then perform a calibration of the rail.
  if (!calibratedSlider) {
    Calibrate();
    //if the calibration has already been done then
    MainLoop();
//calibrate the slider for MAXSlide.
void Calibrate()
  //if the carrage hasnt been homed then home it.
  if (!carrageHomed) {
    HomeCarrage();
    if (calibrationStep == 0)
      Serial.println("calibration step 1 complete");
      calibrationStep = 1;
  if (calibrationStep == 1) {
    //once the carrage is at home send it all the way to the other end of the rail.
    if (MaxSlide == 0) {
      SeekEndStop();
      Serial.println("calibration step 2 complete");
      calibrationStep = 2;
  if (calibrationStep == 2) {
      HomeCarrage();
      Serial.println("calibration step 3 complete");
      calibrationStep = 3;
      calibratedSlider = true;
      carrageDirection(true);
void SeekEndStop() {
  //rest the stall value
  //IM - only run this part the first time we start this process.
  if (!TMC2130enabled)
    Serial.println("########### SeekEndStop ###########");
    resetStallSleep();
    enableTMC2130();
  static int cal_last_time = checkInerval;
  int StallVal;
  //set the carrage direction toward home
  if ((cal_last_time--) == 0) //IM - dont run every loop the stepper driver wont like it!
    //Serial.println("Calibration Mode");
    uint32_t drv_status = driver.DRV_STATUS();
    StallVal = (drv_status & SG_RESULT_bm) >> SG_RESULT_bp;
    //Serial.println(StallVal);
    if (!stallSleep) {
      if (StallVal == 0) {
        stall = true;
        Serial.println("SeekEndStop: stall!");
  if (stallSleep) {
    decrementStallSleep();
  if (!stall) {
    digitalWrite(PIN_STEP, HIGH);
    delayMicroseconds(100);
    digitalWrite(PIN_STEP, LOW);
    calSteps++;
    if (TMC2130enabled) {
      stallSleep = true;
      MaxSlide = calSteps;
      CalcRailLength();
      Serial.print(" ########### Max Slide Found: ");
      Serial.print(MaxSlide);
      Serial.println(" ########### ");
      carragePos = MaxSlide; //as were at the end of the rail then set carrage pos to maxslide.
      disableTMC2130();
//IM - Calculates the lenght of the rail based on the number of steps taken before it hit the end (MaxSlide),
//devided by the number of steps taken in one mm (a fixed value up top calculated for our stepper motor).
void CalcRailLength() {
  //calculate the rail length in MM
  RailLength = MaxSlide / StepsPerMM;
  Serial.print(" ########### Rail Length: ");
  Serial.print(RailLength);
//psudo timer, allows some clock cycles to happen to delay a redetection of a motor stall.
void decrementStallSleep() {
  if (stallSleep) {
    Serial.print("Stall Sleep:");
    Serial.println(stallSleepDuration);
    stallSleepDuration-- ;
    if (stallSleepDuration == 0) {
      Serial.println("STALL SLEEP END");
      stallSleep = false;
//IM - if you know your not stalling out then you can reset the stall sleeper.
void resetStallSleep() {
  stall = false;
  stallSleep = false;
void HomeCarrage() {
  if (!TMC2130enabled) {
    Serial.println("########### Home Carrage ###########");
    enableTMC2130();
    resetStallSleep();
    Serial.print("Check Interval: ");
    Serial.println(checkInerval);
    Serial.print("Stall: ");
    Serial.println(stall);
  int StallVal;
  carrageDirection(false);
    //Serial.println("HomeCarrage: here");
    if (!stallSleep) {
        stall = true;
        Serial.println("HomeCarrage: Stall!");
        stallSleep = true;
  if (stallSleep) {
  if (!stall) {
    stallSleep = true;
    carrageHomed = true;
    carragePos = 0; //IM - Where home!
      Serial.println(" ########### Homed ############");
      //disableTMC2130();
void StartStop() {
  Serial.println("if button pressed");
  //if the slider is running then enable or dissable the stepper.
  if ((sspeed == 0) && (decimals == 0)) {
    srunning = 0;
    Serial.print("######### StartStop: STOPPED #########");
  else {
    Serial.print("######### StartStop: STARTED #########");
    if (carrageHalted == true) {
    srunning = !srunning;
    setPeriod();
  updateLCDStatus();
void MainLoop() {
  static uint32_t last_time = 0;
  uint32_t ms = millis();
  //##################################### ENCODER AND BUTTON START #####################################
  long newPosition = myEnc.read();
  if ((newPosition < 0) && (newPosition < offset)) {
    offset = newPosition;
  newPosition = newPosition - offset;
  //IM If the new position of the rotary encoder is different then..
  if (newPosition != oldPosition) {
    oldPosition = newPosition;
    updateRuntime();
    //Serial.println(newPosition);
    //Serial.print("\n");
    setPeriod();
  //IM - If the interupt has been triggered by the button being pressed, buttonPressed will be true.
  if (buttonPressed) {
    StartStop();
  //##################################### ENCODER AND BUTTON END #####################################
  //##################################### TOUCH SCREEN START #####################################
  // a point object holds x y and z coordinates
  if (!ts.bufferEmpty())
    // Retrieve a point
    TS_Point p = ts.getPoint();
    // Scale using the calibration #'s
    // and rotate coordinate system
    /*TSPoint p = ts.getPoint();
      pinMode(XM, OUTPUT);
      pinMode(YP, OUTPUT);
      // we have some minimum pressure we consider 'valid'
      // pressure of 0 means no pressing!
      //if (p.z > MINPRESSURE && p.z < MAXPRESSURE) {
      if (p.z > ts.pressureThreshhold) {*/
    //IM - Map the touch screen relitive to it size
    p.x = map(p.x, TS_MAXX, TS_MINX, 0, 320);
    p.y = map(p.y, TS_MAXY, TS_MINY, 0, 240);
    //IM - Print the y position value
    //Serial.print("X = "); Serial.print(p.x);
    //Serial.print("\tY = "); Serial.print(p.y);
    //a temporary variable to store the new direction
    int DIR = 0;
    //IM - If the new point os less than the mid value then its to the left.
    //IM - Note: this depends on physical screen orientation! if it is upside down change < to >.
    if (p.x < ts_MID) {
      sdir = 0; //IM - Set the direction bit to 0
      //IM - Write to the pin the direction value
      DIR = 0;
      //Serial.println("left");
    else {
      sdir = 1; //IM - Set the direction bit to 1
      DIR = 1;
      //Serial.println("right");
    //IM - if its a new direction up date the desplay
    carrageDirection(sdir);
    if (sdir != oldsdir) {
      updateLCDStatus();
  //##################################### TOUCH SCREEN END #####################################
  //##################################### BATTERY STATUS CHECK START #####################################
  // if ((long)(millis() - nextBattMillis) >= 0) {
  //update Battery status
  //   nextBattMillis += 10000;
  //   rawVolt = ((float)analogRead(PIN_BATTVOLT)) * 0.02 + rawVolt * 0.98;
  //   volt = toVolt(rawVolt);
  //   tft.setTextColor(WHITE);
  //   if (volt < 8) {
  //    tft.setTextColor(GREEN);
  //  if (volt < 7.2) {
  //   tft.setTextColor(YELLOW);
  // if (volt < 6.5) {
  //    tft.setTextColor(RED);
  // tft.fillRect(0, 110, 150, 22, BLACK);
  // tft.setTextSize(1);
  // tft.setCursor(0, 130);
  // tft.setFont(&FreeSans12pt7b);
  // tft.print(mapFloat(volt, 6, 8.4, 0, 100));   tft.print("% ");
  // tft.print("volt");   tft.print("V ");
  // tft.print("rawVolt");   tft.print("int ");
  // Serial.print("Battery Check:"); Serial.print(volt); Serial.print("; "); Serial.println(millis());
  //##################################### BATTERY STATUS CHECK END #####################################
void updateLcdDirection(bool d) {
  if (!d) {
    tft.fillTriangle(
      320, 200, // peak
      280, 240, // bottom left
      320, 240, // bottom right
      BLACK);
    tft.fillTriangle(
      0, 200, // peak
      40, 240, // bottom right
      tft.color565(255, 0, 50));
  else {
    tft.fillTriangle(
      0, 200, // peak
      BLACK);
    tft.fillTriangle(
      320, 200, // peak
void updateLCDStatus() {
  if (runtime < MINRUNTIME) {
    if (!drawnStatusBlank) {
      tft.fillRect(75, 200, 170, 35, BLACK);
      srunning = 0;
      drawnStatus = 0;
    return;
  else if (drawnStatusBlank || (drawnStatus != srunning)) {
    tft.setTextSize(1);
    tft.setCursor(0, 0);
    tft.setFont(&FreeSans18pt7b);
    if (srunning) {
      tft.setCursor(75, 230);
      tft.print("RUNNING");
    else {
      tft.setCursor(100, 230);
      tft.setTextColor(BLUE);
      tft.print("READY");
    drawnStatusBlank = 0;
//IM Updates the runtime when the rotary encoder is turned.
void updateRuntime() {
  if (oldPosition != 0) {
    runtime = 1000 * oldPosition * oldPosition / 4;
  if (needsInit) {
  else {
    updateLCDTime(false);
  updateLCDStatus();
//IM Updates the LCD with the new run time
void updateLCDTime(boolean firstrun) {
  int days = runtime / day ;                                //number of days
  int hours = (runtime % day) / hour;                       //the remainder from days division (in milliseconds) divided by hours, this gives the full hours
  int minutes = ((runtime % day) % hour) / minute ;         //and so on...
  int seconds = (((runtime % day) % hour) % minute) / second;
  tft.setCursor(0, 20);
  tft.setTextSize(4);
  tft.setFont();
  if (oldPosition == 0) {
    tft.setCursor(42, 70);
    tft.setFont(&FreeMonoBold24pt7b);
    tft.setTextSize(2);
    tft.fillRect(0, 5, 320, 28, BLACK); //clear time
    tft.fillRect(0, 54, 320, 35, BLACK); // clear speed
    tft.print("HALT");
    srunning = false;
    tft.setTextSize(1);
    tft.setFont(&FreeMono18pt7b);
    tft.setCursor(0, 100);
    //   tft.print("0 mm/s");
    sspeed = 0;
    decimals = 0;
    needsInit = true;
  else {
    if (firstrun) {
      tft.fillRect(42, 24, 230, 30, BLACK); //clear HALT/STOP
    tft.setFont(&FreeMonoBold18pt7b);
    tft.setTextSize(1);
    //DAYS
    if ((days != oldDays) || firstrun) {
      tft.setCursor(0, 30);
      tft.fillRect(0, 5, 42, 28, BLACK);
      if (days < 10) {
        tft.print("0");
      tft.print(days);
      oldDays = days;
    //HOURS
    if (firstrun) {
      tft.print("d");
    tft.setCursor(80, 30);
    if ((hours != oldHours) || firstrun) {
      tft.fillRect(80, 5, 42, 28, BLACK);
      if (hours < 10) {
        tft.print("0");
      tft.print(hours);
      oldHours = hours;
    //MINUTES
    if (firstrun) {
      tft.print("h");
    tft.setCursor(160, 30);
    if ((minutes != oldMinutes) || firstrun) {
      tft.fillRect(160, 5, 42, 28, BLACK);
      if (minutes < 10) {
        tft.print("0");
      tft.print(minutes);
      oldMinutes = minutes;
    //SECONDS
    if (firstrun) {
      tft.print("m");
    tft.setCursor(240, 30);
    if ((seconds != oldSeconds) || firstrun) {
      tft.fillRect(240, 5, 42, 28, BLACK);
      if (seconds < 10) {
        tft.print("0");
      tft.print(seconds);
      oldSeconds = seconds;
    if (firstrun) {
      tft.print("s");
      needsInit = false;
    if ((oldPosition + offset) != myEnc.read()) {
      return;
    tft.setCursor(0, 80);
    tft.setTextSize(1);
    //IM INTERESTING.speed = distance over time
    //sspeed = (1000000) / (runtime);
    sspeed = (RailLength * 1000) / (runtime);
    if (runtime < (MINRUNTIME * 2)) {
    tft.print(sspeed);
    tft.print(".");
    decimals = ((1000000000) / (runtime)) - (((1000000) / (runtime)) * 1000);
    //decimals = ((RailLength*1000000) / (runtime)) - (((RailLength*1000) / (runtime)) * 1000);
    if (decimals < 100) {
      if (decimals < 10) {
        tft.print("0");
      tft.print("0");
    tft.print(decimals);
    tft.print(" mm/s");
//########################### TIMER PERIOD ###############################
void setPeriod() {
  Serial.println("########################### set period ########################### ");
  if ((runtime < MINRUNTIME) | ! srunning) {
    Serial.print("srunning: ");
    Serial.println(srunning);
    //disableTMC2130();
    Timer1.stop();
    Serial.print("setPeriod: Timer Stopped");
    Serial.print("\n");
  else {
    //IM - TIMER CODE TO WORKOUT THE RUNNING TIME
      enableTMC2130();
    //calculate the speed in mm/s by deviding the rail lenght by the desired runtime in microseconds
    float ssspeed = (RailLength * 1000) / ((float) runtime);
    float sps = ssspeed * (StepsPerMM);
    float pperiod = (RailLength * 1000) / sps;
    Serial.print("RunTime: ");
    Serial.println(runtime);
    Serial.print("ssspeed: ");
    Serial.println(ssspeed, 7);
    Serial.print("RailLength: ");
    Serial.println(RailLength * 1000);
    Serial.print("sps: ");
    Serial.println(sps, 7);
    pperiod = ((float)runtime) / ((float)MaxSlide);
    Serial.print("setPeriod: ");
    Serial.println(pperiod);
    Timer1.setPeriod(pperiod * 500);
float toVolt(float rawADC) {
  return mapFloat(rawADC, 0, 1023, 0, 10.8); //empirical calibration
float mapFloat(float x, float in_min, float in_max, float out_min, float out_max)
  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
float lookup(float inval, short lut[][2], short clamp) {
  float out;
  byte i;
  for (i = 1; i < LOOKUP; i++)
    if (lut[i][0] > inval)
      return lut[i - 1][1] + (inval - lut[i - 1][0]) * (lut[i][1] - lut[i - 1][1]) / (lut[i][0] - lut[i - 1][0]);
  if (i == LOOKUP) {
    return clamp;
Ok, what are the limits, my aim was only 600ma, Still too much?
Thanks for the code.
You now need to write code JUST for the stepper, forget the display for now.
So disconnect everything, connect JUST the driver and stepper and write some code to just make it run and stop in a cycle.
Using a simple code to get your stepper running will help to prove your hardware before adding the extras. You are in troubleshooting mode now and little codes to test hardware will help to find your problem, without it being masked by other code.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
Unfortunately, I literally can't do that. Regardless of what code is on the Arduino. The second I put 5v into the stepper driver from Arduino the Arduino shuts off. Even with nothing else connected, I'm assuming there is a shot or something fucky going on with the Stepper driver in question.
I will say "Yes" as I don't know the width and the thickness of those copper strips. 100 mA is surely safe, maybe 200 mA but then I say strop.
Well now is the time to post some images of your project, not just one but many showing the components and power supply.
That ought to be safe. I would like to see the datasheet of that driver. As You power the controller by 12 volt the margin is really slim regarding current out take on the 5 volt pin. Do You power any other device from the Mega 5 volt pin? That could be bad.
