how would i go about adding another sensor to this code?
#define BLYNK_PRINT Serial
#include <SPI.h>
#include <WiFiNINA.h>
#include <BlynkSimpleWiFiNINA.h>
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(true); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "Ljw476ueM961rrT2Xr9fzhXCoY4bC5yN";
// Your WiFi credentials.
char ssid[] = "Home Wifi";
char pass[] = "ZeldaDaphne1";
// Debug console
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
dht.begin();
// Setup a function to be called every second
timer.setInterval(1000L, sendSensor);
Blynk.run();
timer.run();
Current_sensor_project-1sensor_blynk.ino (1.26 KB)
