Hi! i am new to arduino.. I want to interface dht11 and max 30102 pulse oximeter sensor using blynk but the values for the dht11 are not showing , Onl
#include <Wire.h>
#include <Blynk.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include "MAX30105.h"
#include "spo2_algorithm.h"
#include "heartRate.h"
#include <DHT.h>
#define DHTPIN 2
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
MAX30105 particleSensor;
#define MAX_BRIGHTNESS 255
#if defined(AVR_ATmega328P) || defined(AVR_ATmega168)
uint16_t irBuffer[100]; //infrared LED sensor data
uint16_t redBuffer[100]; //red LED sensor data
#else
uint32_t irBuffer[100]; //infrared LED sensor data
uint32_t redBuffer[100]; //red LED sensor data
#endif
#define REPORTING_PERIOD_MS 1000
char auth[] = "YE3_5qO9htDJsSWi8dp24vP-2tZmHJIV"; // You should get Auth Token in the Blynk App.
char ssid[] = "MUFIKA.S"; // Your WiFi credentials.
char pass[] = "Iyaloo0910!";
uint32_t tsLastReport = 0;
int32_t bufferLength; //data length
int32_t spo2; //SPO2 value
int8_t validSPO2; //indicator to show if the SPO2 calculation is valid
int32_t heartRate; //heart rate value
int8_t validHeartRate; //indicator to show if the heart rate calculation is valid
byte pulseLED = 4; //Must be on PWM pin
byte readLED = 5; //Blinks with each data read
int sp02Avg = 0;
int HRAvg = 0;
Blynk.begin(auth, ssid, pass);
Serial.begin(115200); // initialize serial communication at 115200 bits per second:
dht.begin(); // Initialize sensor
timer.setInterval(1000L, sendSensor); // Setup a function to be called every second
pinMode(pulseLED, OUTPUT);
pinMode(readLED, OUTPUT);
if (!particleSensor.begin(Wire, I2C_SPEED_FAST)) //Use default I2C port, 400kHz speed
Serial.println(F("MAX30105 was not found. Please check wiring/power."));
while (1);
Serial.println(F("Attach sensor to finger with rubber band. Press any key to start conversion"));
while (Serial.available() == 0) ; //wait until user presses a key
Serial.read();
byte ledBrightness = 60; //Options: 0=Off to 255=50mA
byte sampleAverage = 4; //Options: 1, 2, 4, 8, 16, 32
byte ledMode = 2; //Options: 1 = Red only, 2 = Red + IR, 3 = Red + IR + Green
byte sampleRate = 100; //Options: 50, 100, 200, 400, 800, 1000, 1600, 3200
int pulseWidth = 411; //Options: 69, 118, 215, 411
int adcRange = 4096; //Options: 2048, 4096, 8192, 16384
particleSensor.setup(ledBrightness, sampleAverage, ledMode, sampleRate, pulseWidth, adcRange); //Configure sensor with these settings
bufferLength = 100; //buffer length of 100 stores 4 seconds of samples running at 25sps
//read the first 100 samples, and determine the signal range
for (byte i = 0 ; i < bufferLength ; i++)
while (particleSensor.available() == false) //do we have new data?
particleSensor.check(); //Check the sensor for new data
redBuffer[i] = particleSensor.getRed();
irBuffer[i] = particleSensor.getIR();
particleSensor.nextSample(); //We're finished with this sample so move to next sample
Serial.print(F("red="));
Serial.print(redBuffer[i], DEC);
Serial.print(F(", ir="));
Serial.println(irBuffer[i], DEC);
//calculate heart rate and SpO2 after first 100 samples (first 4 seconds of samples)
maxim_heart_rate_and_oxygen_saturation(irBuffer, bufferLength, redBuffer, &spo2, &validSPO2, &heartRate, &validHeartRate);
//Continuously taking samples from MAX30102. Heart rate and SpO2 are calculated every 1 second
while (1)
Blynk.run();
//dumping the first 25 sets of samples in the memory and shift the last 75 sets of samples to the top
for (byte i = 25; i < 100; i++)
  redBuffer[i - 25] = redBuffer[i];
  irBuffer[i - 25] = irBuffer[i];
//take 25 sets of samples before calculating the heart rate.
for (byte i = 75; i < 100; i++)
  digitalWrite(readLED, !digitalRead(readLED)); //Blink onboard LED with every data read
//After gathering 25 new samples recalculate HR and SP02
float t = dht.readTemperature();
float h = dht.readHumidity();
Serial.print(F("\t SPO2="));
Serial.print( sp02Avg , DEC);
Serial.print(F("\t SPO2Valid="));
Serial.println(validSPO2, DEC);
Serial.print(F("\t ValidHeartrate="));
Serial.println(validHeartRate, DEC);
Serial.print(F("\t Heartrate="));
Serial.println(HRAvg, DEC);
//Calculates average SPO2 to display smooth transitions on Blynk App
if(validSPO2 == 1 && spo2 < 100 && spo2 > 0)
  sp02Avg = (sp02Avg+spo2)/2;
  spo2 = 0;
  sp02Avg = (sp02Avg+spo2)/2;;
//Start
if(validHeartRate == 1 && heartRate < 100 && heartRate > 0)
  HRAvg = (HRAvg + heartRate)/2;
  heartRate = 0;
 //Send Data to Blynk App at regular intervals
if (millis() - tsLastReport > REPORTING_PERIOD_MS)
  Blynk.virtualWrite(V4, sp02Avg);
  Blynk.virtualWrite(V3, HRAvg);
  tsLastReport = millis();
void sendSensor()
float h = dht.readHumidity(); //Read the humidity
float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
Serial.println("Failed to read from DHT sensor!");
return;
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
Does dht11 sensor work on its own?
Yes it does
i think its the while loop that`s confusing in the void loop
What gets your code out of the while(1) loop?
Please remember to use code tags when posting code.
I finally got to make it work but since I am using the MAX30102 to use up the pins of SCL/SDA on the esp8266,,, I also want to print the values using an LCD screen That also uses I2C protocol to print please help ? How do i go about it
Make parallel connections of the SCL/SDA lines of both LCD and MAX30102; but, give 5V supply to the Vcc-line of the LCD from separate supply. The LCD will not work at 3.3V supply from the ESP8266.
Okay thank you I will try It out
Thank You man my project finally worked.
Congratulation!
