Adding commands to play .mp3
I have the below code working to spin a stepper motor. I have the arduino connected to an .mp3 card, but need to add the code to get it to play. I have added what I believe is the correct code (see below in red). Any help is appreciated. Thanks in advance
Stepper Motor Control - one revolution
This program drives a unipolar or bipolar stepper motor.
The motor is attached to digital pins 8 - 11 of the Arduino.
The motor should revolve one revolution in one direction, then
one revolution in the other direction.
Created 11 Mar. 2007
Modified 30 Nov. 2009
by Tom Igoe
#include <Stepper.h>
int x = 0;
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
// for your motor
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, 8, 9, 10, 11);
// set the speed at 60 rpm:
myStepper.setSpeed(63);
// initialize the serial port:
if (x <= 10)
{ // step one revolution in one direction:
Serial.println("clockwise");
myStepper.step(stepsPerRevolution);
// delay(500);
x++;
// step one revolution in the other direction:
// Serial.println("counterclockwise");
// myStepper.step(-stepsPerRevolution);
// delay(500);
void setup(){
** Serial.begin(4800);**
void loop(){
** Serial.write(0x01);**
Please read this:-
How to use this forum
Because your post is breaking the rules about posting code.
Now post code that compiles or post the error message you get when it fails as that code you posted fails.
Here is a clue, it is not even remotely correct, and does not begin to address what you need to do.
You are trying to do something that is too hard for your present knowledge. Do some more tutorial examples before attempting this.
