Adding ir receiver
hi everyone
im new to arduino
this is my code the aim of this is to remotely activate it
they leds flash and stop randomly, there are two colors
i just need to know what to write
const int buttonPin = 2; // Pin number for the button
const int led1Pin = 9; // Pin number for the first LED
const int led2Pin = 10; // Pin number for the second LED
bool isFlashing = false;
pinMode(buttonPin, INPUT_PULLUP); // Set button pin as input with internal pull-up resistor
pinMode(led1Pin, OUTPUT); // Set LED1 pin as output
pinMode(led2Pin, OUTPUT); // Set LED2 pin as output
Serial.begin(9600); // Initialize serial communication
// Check if the button is pressed
if (digitalRead(buttonPin) == LOW) {
// Wait for button release to avoid bouncing issues
while (digitalRead(buttonPin) == LOW) {}
// Start flashing LEDs
isFlashing = true;
// Seed the random generator
randomSeed(analogRead(A0));
// Flash LEDs alternately
while (isFlashing) {
  digitalWrite(led1Pin, HIGH);
  digitalWrite(led2Pin, LOW);
  delay(100); // Adjust delay as needed
  digitalWrite(led1Pin, LOW);
  digitalWrite(led2Pin, HIGH);
  // Randomly decide whether to stop flashing
  if (random(0, 100) < 5) { // 5% chance to stop each cycle
    isFlashing = false;
    // Randomly choose the LED to leave on
    if (random(0, 2) == 0) {
what im wanting to do is add code for an ir receiver to act as the button
the button can be left on
at present i cant get it to work
ir pins are
g- ground
v-5volt
s-pin 3
the program works fine with just button
i have managed to get the hex for button on remote i just dont know how to add the code for ir into this code
everything i look up says error wrong ir library stuff
im assuming its just outdated code pre 2019 or something
i used chatgpt to get this code but yeah cant get it to do succesful ir extra
thanks all
