Let me rephrase your solution: Velocity = deltaDistance / deltaTime;
Required is the last distance and time for calculating the difference to the current distance and time.
We would love for you to try and propose something. The purpose of the forum is to help you, not do it for you (esp. as it looks like a school homework)
To calculate speed you will need to take 2 separate distance readings and know the time between them. Then (reading1 - reading2) / time gives you a speed.
So make a start by saving 2 distance readings with a known time between them. What sort of speeds are you dealing with?
You promised the compiler that your readDistance function would return an int, but it doesn't.
(And if it did, neither duration not distance would require global scope.)
Here is an example of one way to do it. By measuring distance every tenth of a second (100 milliseconds) we can easily calculate speed in centimeters per second by multiplying the change in the distance by 10.
const int TriggerPin = 9;
const int EchoPin = 10;
unsigned maximumRange = 119; // Maximum range needed
unsigned minimumRange = 12; // Minimum range needed
Serial.begin (9600);
pinMode(TriggerPin, OUTPUT);
pinMode(EchoPin, INPUT);
unsigned long currentTime = millis();
static unsigned long lastReadingTime = 0;
// Let's take 10 samples per second
if (currentTime - lastReadingTime >= 100)
lastReadingTime = currentTime;
unsigned distance = readDistance();
static unsigned oldDistance = 0;
if (distance > minimumRange && distance < maximumRange)
Serial.print(distance);
Serial.print(" cm, ");
if (distance > oldDistance)
Serial.print((distance - oldDistance) * 10);
Serial.println(" cm/s away");
else if (distance < oldDistance)
Serial.print((oldDistance - distance) * 10);
Serial.println(" cm/s toward");
oldDistance = distance;
unsigned readDistance()
digitalWrite(TriggerPin, LOW);
delayMicroseconds(2);
digitalWrite(TriggerPin, HIGH);
delayMicroseconds(10);
// 10 millisecond timeout. 119 cm
// is about 7 milliseconds echo time
unsigned long duration = pulseIn(EchoPin, HIGH, 10000);
return duration / 58.2;
Thanks, I change the project to 3 sensors and dropped the speed. I could not work it out.
The code with the 3 sensors and data on one line to import it on a data sheet in excel seems to work okay.
You have any recommendations?
#include <NewPing.h>
#define TRIGGER_PIN 4
#define ECHO_PIN 5
#define TRIGGER_PIN2 8
#define ECHO_PIN2 9
#define TRIGGER_PIN3 12
#define ECHO_PIN3 13
#define MAX_DISTANCE 150 // Maximum distance we want to measure (in centimeters).
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
NewPing sonar2(TRIGGER_PIN2, ECHO_PIN2, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
NewPing sonar3(TRIGGER_PIN3, ECHO_PIN3, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
delay(500); // Wait 50ms between pings (about 20 pings/sec). 29ms should be the shortest delay between pings.
int distance = sonar.ping_cm(); // Send ping, get distance in cm and print result (0 = outside set distance range)
Serial.print(',');
int distance2 = sonar2.ping_cm();
Serial.print(distance2);
Serial.print(',');
int distance3 = sonar3.ping_cm();
Serial.println(distance3);
That delay is only between the third and the first. The second sensor is likely to pick up late echoes from the first and the third is likely to pick up late echoes from the second. Put delays between each:
Serial.print(',');
delay(50);
Serial.print(',');
delay(50);
// Wait another 400 milliseconds (500 total) to slow down the serial output
delay(400);
