Sounds "basically" like a voltage divider... using buttons, 1% tolerance resistors... except for the "infinite buttons at one time." Maybe a series of 74HC165 shift registers?
Buttons with resistors are unreliable, and that gets worse over time when the contacts oxidise.
Shift registers with SPI only work over short distances. 32 buttons in a row...
Maybe OP should tell us more about the project.
Leo..
The OneWire DS2413 I linked to in post#4 has two I/O pins.
It seems that one can be used for a button, and the other one for a feedback LED.
Two (or three) wires, all the way to button 32.
OP could be the first one to try this.
Leo..
That distance depends on SPI clock speed that does have a default divider of 4 but can be higher. I can say the same about 3 wire serial.
The same chain can be run fast using bit shifting. And that all is just the distance to the chained registers, from those to the buttons is another matter which the button circuitry addresses.
Blanket "you can't" become beginner electronic factoids that surface in threads over design choice.
You need press all button to read and put into array when press a especial button
or modify code and put the value of all 1 wire into array.
When use auto read, the order into array will be the first serial into first array position
and so on....
#include <OneWire.h> // One wire lib
//https://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
#define readOneWires 4 // Button for read all One Wires and save at array
OneWire ds(3); // Connect your 1-wire device to pin 3
byte myCount = 0; // Onewire found
unsigned int OneWireAdd[32] = {0}; // Array for onewire add
bool flag = false; // Msg control
unsigned long reReadTime = 5000; // Time between 2 reads
unsigned long lastRead = 0; // Last read time
void setup(void) {
pinMode(readOneWires, INPUT_PULLUP); // Button for read bus
lastRead = millis(); // Start first read time
void discoverOneWireDevices(void) { // Discover One Wire Devices on bus
byte i; // General control
byte present = 0; // Present Bit of one wire
byte addr[8]; // EEPROM from one wire
Serial.print("Looking for 1-Wire devices...\n\r");
while (ds.search(addr)) {
Serial.print(" 1-Wire address: ");
for ( i = 0; i < 8; i++) {
Serial.print("0x");
if (addr[i] < 16) {
Serial.print('0');
Serial.print(addr[i], HEX);
if (i < 7) {
Serial.print(", ");
for (i = 1; i < 7; i++)
OneWireAdd[myCount] += addr[i];
Serial.print(" Add: "); Serial.println(OneWireAdd[myCount], HEX);
myCount++;
if ( OneWire::crc8( addr, 7) != addr[7]) {
Serial.print("CRC is not valid!\n");
return;
Serial.print("Table loaded.\r\n");
ds.reset_search();
return;
void readButtons(void) { // Read One Wire Devices on bus to id button pressed
unsigned int compare = 0; // Button pressed value read to compare to array
Serial.print("Looking buttons pressed...\n\r");
//Serial.print("0x");
if (addr[i] < 16) {
//Serial.print('0');
if (i < 7) {
compare += addr[i];
return;
for (int i = 0; i < myCount; i++)
if (compare == OneWireAdd[i])
Serial.print("button pressed "); Serial.println(i);
compare = 0;
Serial.print("Bus readed.\r\n");
ds.reset_search();
return;
void loop(void) {
if (digitalRead(readOneWires) == LOW) {
delay(30); // Debounce
discoverOneWireDevices(); // Read One Wires serial and save at array
while (digitalRead(readOneWires) == LOW) {
if (OneWireAdd[0] == 0x00) { // if bus not read
if (flag == false) {
Serial.println("Array empty");
Serial.println("Press readOneWires button to read series");
flag = true;
return;
if ( millis() - lastRead >= reReadTime)
if (OneWireAdd[0] |= 0x00) { // Array full
readButtons();
Yep. Many years ago we implemented an LED and push button "pick-to-light" system using CMOS shift registers (so we could run 12V signals for better noise immunity) that ran for hundreds, if not thousands of feet in a very large room.
For those who are more interested in project, I will give a quick description.
I am making interactive hallway. That is composed of pressure plates with LEDs. I want to be flexible with width and length. So one length would be one chain. I would like for each module to be separate and same as all the rest. So in case of faulty one I would just remove it and plug in new one. Each modul would probably be 30cmx30cm. So for just 10m I am already over 30 moduls. Whole thing will probably be around 500 moduls.
