I have got these working if anyone is still interested.
Here follow two programs, one for simple control, and the other setting up an array of colours:
/*Code for driving OST4ML5B32A addressable rgb leds
* Developed by Oliver Rokison at Hampton School
* The circuit for the first LED in the string is as follows:
* Pin 1 (DIN) to pin 3 on Arduino
* Pin 2 (VDD) to 5V on Arduino
* Pin 3 (GND) to GND on Arduino
* Pin 4 (DOUT) to DIN of next LED
* You MUST also connect a 1K resistor fron Pin 1 to 5V, and a 1K resistor from Pin 1 to 0V (on the first LED only)
* This gives the three voltage levels required by the LED
* Connect other LEDs in the same way, but with Pin 1 (DIN) connected to Pin 4 (DOUT) of the previous LED
#define LED_PIN 3 // the data pin from the Arduino to your string of LEDs
#define DELAY 50 // the pulse width in microseconds (plus the 2 microseconds or so that the digitalWrite command takes)
pinMode(LED_PIN, INPUT);
// the sendColour command takes 3 bytes (R,G & B values from 0-255) and displays that colour on the LED
sendColour(0, 255, 0); //Note, this will control the last LED in your string
//place other sendColour commands in here depending on how many LEDs in your string
sendColour(255,0,0); //This will control the first LED
delay(10); // datasheet requires at least 3ms between refreshes, but we have used 10 for safety
void sendColour(byte r, byte g, byte b) {
sendByte(b); // we send the blue first
sendByte(g); // then the green
sendByte(r); // then the blue
void sendByte(byte b) {
// each byte is sent LSB first and is 8 bits long
for (int n = 7; n >= 0; n--) {
// if we have a high bit, set up the digitalWrite first, then make the pin an output
// this will engage the 10K internal pullup resistor, but in compariosn to our 1K potential divider, this shouldn't affect the logic level
if (bitRead(b, n)) {
digitalWrite(LED_PIN, HIGH);
pinMode(LED_PIN, OUTPUT);
delayMicroseconds(DELAY);
// otherwise, if we have a low bit, make the pin an output first and then check it is LOW
else {
digitalWrite(LED_PIN, LOW);
And now with an array:
/* Code for driving OST4ML5B32A addressable rgb leds
* Developed by Oliver Rokison of Hampton School
// this is where you define the RGB colours you want each LED to display, startng with the one nearest the Arduino
byte Colours[][3]={
{0,255,0},
{255,0,0},
// the colours are set in reverse order
for(int i=((sizeof(Colours)/sizeof(byte))/3)-1; i>=0;i--){
sendColour(Colours[i][0], Colours[i][1],Colours[i][2]); //Note, this will control the last LED in your string
delay(10); // datasheet requires at least 3ms between refreshes, but we have used 10 for safety, and we only do this at the end
else {
