Adjustable speed pulse trains
Hi
I have 2 stepper motors
Each needs a string of pulses and iether a high or low signal to select forwards or reverse
I want to use a joystick that has 4 switches on it to control the two steppers
X Left/Right and Y Up/Down and a slider pot to control speed
I dont need to count pulses to move a set distance , They will move till I release the joystick
I know I can use something like
To move left
If input left is high then send pulses out to the left/right motor and make its direction pin high
or to move right
if input right is high then send pulses out to the left/right motor and make its direction pin low
and the same for up./down
I know I can change the speed by reading the pot value on an analogue pin
I believe using delay for making the pulse train will be a non starter and I must use millis or
maybe an ISR but I dont know how to do that
How can I ( using millis or an ISR ) make a pulse train start at the speed I selected when it detects that a joystick has been activated ?
Hope someone can help
Don
What kind of steppers? What kind of driver? Most stepper drivers need the direction pin set HIGH to rotate one way and LOW to rotate the other way. I've never heard of one that takes a string to control direction. Or even one that needs more than one change of level.
Start by having a look at these links
Stepper Motor Basics
Simple Stepper Code
especially the second code example that uses millis()
Also have a look at the AccelStepper library. It is not necessary to use the library but you may find it useful.
You should also post a link to the datasheet for your stepper motor and tell us what stepper motor driver you are using.
...R
Hi Paul
PaulS:
No , Im not suggesting to send a series of pulses to the direction pin
lets see if I can explain it better with a pseudo program
The joystick left switch is connected to arduino pin 3
the joystick right switch is connected to arduino pin 4
the stepper driver direction input connects to arduino pin 5
the stepper motor pulse ( step) input connects to arduino pin 6
Now for the X axis stepper
If pin 3 is high // joystick is pushed right
set pin 5 High // set direction to CW
start sending pulses to pin 6 // Move the stepper
continue sending pulses till joystick is released
if Pin 3 is low // Joystick is pushed left
set pin 5 Low // set direction to CCW
start sending pulses to pin 6 // stepper
and then of course I need to do the same for the y axis motors
setting the direction and making it move is not the problem
I did that when I built my cnc mill
but with that I always send the pulses out at a fixed speed .
Now I want to be able to vary the speed of the pulses by reading the
value of a pot on an analogue input, and preferably 2 different speeds
one from a pot on each axis
I know I cant use delay to do it as that ties the arduino up all the time its in a
delay loop. I assumed that millis or an ISR would be the way to go but have
no experience using those
Regards
Don
Robin2:
...R
Hi Robin
I didnt see how what kind of stepper or driver would alter the info I was after
as I already know how to drive them
it was how to make a variable speed pulse train using millis or an ISR that I needed but if it helps
the driver is an MSD415 http://www.motioncontrolproducts.com/drives/msd415-microstepping-drive.php?cat=2
your links that you gave me look promissing and I will go read them now
Thank you
Don
Hi Robin
You were right the second example looks perfect
if I map the analogue input to the millisbetweenSteps variable
it will change the speed
Thats great thanks
Don
Glad to hear you are making progress
DonRecardo:
When trying to help it is impossible to know how much the questioner knows or does not know and I have seen Threads run to 30 or 40 Replies before some critical piece of data emerges. So my policy is to try to get all the facts up front :slight_smile:
...R
