Advanced chart time axis wrong time zone
hi,
when using the advanced chart i noticed the X axis (Time line) is in the wrong Time Zone (UTC-5) while the regular chart is on the correct Time Zone (UTC+2).
As you can see in the screen shot of the 2 graphs side by side.
if anybody knows how i can fix this or who to ask I'd really appreciate it.
see
Hi @iam_me4654123m. Are the Arduino Cloud IoT Variables that are linked in these two Arduino Cloud IoT Widgets from different Things?
If yes, check to see if the problem is caused by the time zone configuration in the metadata of the Thing for the Variable that has the wrong time zone in the dashboard.
I provided instructions for checking and adjusting the Thing time zone configuration in your other topic here:
Thanks,
The time zone was set incorrectly to New York, UTC-5.
I corrected the time zone on this THING and set it to UTC+2.
But the advanced chart still shows UTC-5.
The two graphs are connected to the same THING and the same variable.
The advanced chart shows UTC-5 and the regular chart shows the correct time UTC+2.
SOLVED !
After correcting the time zone like @ptillisch advised then deleting the advanced chart and adding it again. It now shows the correct time.
Thanks
You are welcome. I'm glad it is working now. Thanks for taking the time to post an update with your findings!
Regards, Per
