New library released and even bug-fixed to version 0.2.
In my sketches I almost ever need to indicate the states with LED. The LED and the button and LED is one but states are two - the button pressed and the button is released. What if it would blink 1 time per second when the button is released and it would blink fast when the button is pressed?
Now with LEDseq library it blinks as it should. Using interrupts from timer/counter 1 (or it can use 2 if defined in <LEDseq.h> header).
Timer resolution is 4 ms. It can blink fast, very fast.
Delays are 16-bit word. It can lite long, very long.
Download LED sequence solution now and start blinking as pro today!
http://sourceforge.net/projects/ledseq/files/latest/download
