I'm new to Arduino and trying to control a 16x2 LCD through serial from a C# application.
I have the following requirements in terms of functionality:
- Reset the display
- Turn the display on
- Turn the display off
- Send text to a specific line and align it
After some tinkering I got the following code. While everything seems to work, I'm sure this is far from a good or "best practice" solution. Especially the part handling the text feels horrible dirty. Any help on optimizing this would be highly appreciated!
LiquidCrystal Library - RetroBox
Useful links
https://omerk.github.io/lcdchargen/
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
// custom lcd characters used by the logo
byte logoChar0100[8] = {0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00001};
byte logoChar0101[8] = {0b00011, 0b00011, 0b00011, 0b00001, 0b00001, 0b01111, 0b11001, 0b00011};
byte logoChar0102[8] = {0b11000, 0b11000, 0b11000, 0b10000, 0b10000, 0b11110, 0b10011, 0b11000};
byte logoChar0103[8] = {0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b00000, 0b10000};
byte logoChar0200[8] = {0b00001, 0b00001, 0b00001, 0b00001, 0b00001, 0b00000, 0b00000, 0b00000};
byte logoChar0201[8] = {0b00000, 0b01000, 0b11100, 0b01000, 0b00000, 0b11000, 0b01110, 0b00001};
byte logoChar0202[8] = {0b00000, 0b00010, 0b00110, 0b00100, 0b00000, 0b00011, 0b01110, 0b10000};
byte logoChar0203[8] = {0b10000, 0b10000, 0b10000, 0b10000, 0b10000, 0b00000, 0b00000, 0b00000};
// define the backlight pin
int backLight = 13;
#define SOP '<'
#define EOP '>'
bool started = false;
bool ended = false;
char inData[80];
byte index;
int i;
// set the size of the LCD
lcd.begin(16, 2);
// initialize the serial communications:
// enable backlight
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH);
// write the logo
writeLogo();
// Read all serial data
while(Serial.available() > 0)
char inChar = Serial.read();
if(inChar == SOP)
index = 0;
inData[index] = '\0';
started = true;
ended = false;
else if(inChar == EOP)
ended = true;
if(index < 21)
inData[index] = inChar;
index++;
// Process the result
if(started && ended)
// Do the actual processing
processData();
// Reset for the next packet
started = false;
ended = false;
index = 0;
void processData() {
// Text command
// Arguments: line number, alignment, text
// Example: <text:1:r:foobar>
if (memcmp(inData, "text", 4) == 0)
// Parse the line number
// Valid arguments: 1 or 2
int row = 0;
if (inData[5] == '2') {
row = 1;
// Parse the text
// Valid arguments: String (12 characters)
int textIndex = 0;
char text[12];
for(int i = 9; inData[i] != '\0'; ++i) {
text[textIndex] = inData[i];
textIndex++;
// Parse the direction
// Valid arguments: (l)eft, (c)enter, (r)ight
int offset = 4;
if (inData[7] == 'r') {
offset = 16 - strlen(text);
else if (inData[7] == 'c') {
offset = ((16 - strlen(text)) / 2);
// Clear the current text
lcd.setCursor(4, row);
lcd.write(" ");
// Write the new text
lcd.setCursor(offset, row);
lcd.write(text);
// Reset command
// Command: <reset>
if (strcmp(inData, "reset") == 0)
lcd.clear();
writeLogo();
// LCD off command
// Command: <off>
if (strcmp(inData, "off") == 0)
digitalWrite(backLight, LOW);
lcd.noDisplay();
// LCD on command
// Command: <on>
if (strcmp(inData, "on") == 0)
lcd.display();
void writeLogo() {
// Clear the lcd
lcd.clear();
// Define custom characters
lcd.createChar(0, logoChar0100);
lcd.createChar(1, logoChar0101);
lcd.createChar(2, logoChar0102);
lcd.createChar(3, logoChar0103);
lcd.createChar(4, logoChar0200);
lcd.createChar(5, logoChar0201);
lcd.createChar(6, logoChar0202);
lcd.createChar(7, logoChar0203);
// Write logo
lcd.setCursor(0, 0);
lcd.write(byte(0));
lcd.write(byte(1));
lcd.write(byte(2));
lcd.write(byte(3));
lcd.setCursor(0, 1);
lcd.write(byte(4));
lcd.write(byte(5));
lcd.write(byte(6));
lcd.write(byte(7));
// Write text
lcd.setCursor(4, 0);
lcd.write("RetroBox");
lcd.setCursor(4, 1);
lcd.write("idmedia.no");
