I'm currently working with the Arduino Uno and the ADXL335 Lilypad accelerometer. I've managed to get read the values from the analogue ports for the X/Y/X axis. I'm assuming these values are in millivolts however I'm trying to convert them into G's. I have no idea on what calculations to carry out from this point and how to implement that into my code.
I've found this data sheet for it but in all honesty I have no idea on what I have to do. I'm currently getting values such as 350 400 270 for the X Y Z ports. I'm not sure what I should do after finding the sensitivity factor (which I can't find).
I'm not being lazy. Sorry for sounding stupid but I absolutely have no idea.
So if I'm trying to print the values collected simply in G's, I would have to convert a value of say 400 mV from the X axis to G's, then would I simply subtract 300 from the value? That would give me 100 surely which is incorrect?
Actually, the voltage output of the ADXL335 is about Vcc/2 or 1.5V (if powered by 3V) when there is no acceleration (you must determine that value experimentally) and it varies from that by about +/- 300 mV per g, depending on the direction of the acceleration.
A few moments with Google will be well spent, as that will direct you to several tutorials, like this one from Adafruit.
jremington:
jajajajajja your last sentences remind me to Yoda from Star Wars
Esta Web esta muy bien pero al puntuar siempre me marca que el 85% estan correctas cuando en realidad estan bien.
Le pediria al equipo de dessarolladores de eweb de repararlo, como Henry Porche a un Tanque de su propia marca en la segunda guerra mundial.
Personajes que participaron: Adolfo Hitlero
Destacar tambien otro personaje como seria As de tanques alemanes Michel Witman.
Hitler, Winston Churchill, Benito Musssolini, Iosif Stalin, Franklin Roosevelt. Como datos de interes decir que los españoles inventaron inventos tales como Submarinos, helicopteros, la fregona, i el control remoto entre otros. El de la fregona seria el que ha triunfado mas ya que como sabrán todo el mundo tiene en su casa una de ellas, asi que suponemos que si consiguio en su epoca patentarla, se enriquecio increiblemente i acabo su vida de la manera mas lujosa posible. Ya que no todo el mundo puede inventar un instrumento de tanto ingenio y complejidad como es un palo con arapos enganchados.
Con la colaboración de Roy y la real academia de la lengua española (RAE)
Gracias por su atención.
Commandante de la Luftvafe y la Raf; Alfonso Kurtafen Caveman
