Adxl345 value stuck occasionally
Hi, everyone,
We use 3-Axis Digital Accelerometer(±16g) to detect object moving.
We keep reading the z-axis value at 100Hz to monitor object movement. Usually, even the meter module is static, we can observe small vibration in z-axis value, but we found that the accelerometer sometimes stuck at a random value, for example, it just keep returning 285. Sometimes it gets back to normal (with vibrating values) in just seconds, but we also meet some cases that the meter stuck for hours.
So now we keep watching on the z-axis value and once the value stuck for a certain period, we consider the meter is [out-of-control] is ignores all following values until the z-axis value varies again.
Does anyone know how to solve the situation, or how to confirm that the meter is working properly.
Thanks.
Unless the sensor is defective, the problem is most likely in your code or wiring. For help with the latter two, please read and follow the directions in the "How to get the best out of this forum" post.
