ADXL345 with Arduino Uno
Hi All,
I am using Arduino Uno R3 to communicate with ADXL345 accelerometer. Ideally I am trying to built fall detection system BUT at the moment I am stuck to get basic correct communication from sensor. I am not getting right values for x, y and z axis for +-2g, +-4g, +-8g and +-16g. I am getting readings from accelerometer and they also change when I move the board but they are not according to the SENSITIVITY values given in ADXL345 datasheet (page 4 of 40) for each g. Please see following code I picked up from sparkfun. I think my problem is to add two signed bytes. Please see my code as follow.. I would appreciate help from you all
#include <SPI.h>
#define PINNUMBER
int CS=10;
char values[10];
int x,y,z;
double xg, yg, zg;
char ff=0;
long line = 0;
#define   DEVID      0x00   //Device ID Register
#define POWER_CTL   0x2D   //Power Control Register
#define   DATA_FORMAT   0x31   //Data format control
#define DATAX0      0x32   //X-Axis Data 0
#define DATAX1      0x33   //X-Axis Data 1
#define DATAY0      0x34   //Y-Axis Data 0
#define DATAY1      0x35   //Y-Axis Data 1
#define DATAZ0      0x36   //Z-Axis Data 0
#define DATAZ1      0x37   //Z-Axis Data 1
void setup(){
  SPI.begin();
  SPI.setDataMode(SPI_MODE3); //configure accelerometer for SPI connecttion
  pinMode(CS, OUTPUT); //set chip select to be output
  digitalWrite(CS, HIGH); //set chip select to be high
  writeRegister(DATA_FORMAT, 0x01); //put accelerometer into 16G range
  writeRegister(POWER_CTL, 0x08);  //Measurement mode
void loop(){
  readRegister(DATAX0, 6, values);
int i;
  x = ((int)values[1]<<8)|(int)values[0];
  y = ((int)values[3]<<8)|(int)values[2];                 //I think my problem is in these three lines.. calculations to add two signed bytes.
  z = ((int)values[5]<<8)|(int)values[4];
//    x = values[1] << 8;
//    x+= values[0];
  for (i=0; i<6; i++)
     Serial.print(values[i], DEC);
     Serial.print(" ");
  Serial.print("X: ");
  Serial.print(x, DEC);
  Serial.print(',');
  Serial.print("Y: ");
  Serial.print(y, DEC);
  Serial.print(',');
  Serial.print("Z: ");
  Serial.print(z, DEC);
  Serial.print(',');
  //convert accelerometer value to G
 // xg = x * 0.0039;
 // yg = y * 0.0039;
 // zg = z * 0.0039;
  //Print the results to the terminal so that i can monitor the reading using the serial monitor.
 // Serial.println ();
 // Serial.print("xg: ");
 // Serial.print((float)xg,2);
 // Serial.print("g,");
 // Serial.print("yg: ");
 // Serial.print((float)yg,2);
 // Serial.print("zg: ");
 // Serial.print((float)zg,2);
//  Serial.println("g");
  delay(1500);
//  char registerAddress - The register to write a value to
//  char value - The value to be written to the specified register.
void writeRegister(char registerAddress, char value){
  //Set Chip Select pin low to signal the beginning of an SPI packet.
  digitalWrite(CS, LOW); // to signal beginning of SPI packet
  SPI.transfer(registerAddress);
  SPI.transfer(value);
  digitalWrite(CS, HIGH); // to signal end of SPI packet
void readRegister(char registerAddress, int numBytes, char * values){
  char address = 0x80 | registerAddress; // to perform read operation the most significant bit of the register address must be set
  if(numBytes > 1)address = address | 0x40;
  SPI.transfer(address);
  for(int i=0; i<numBytes; i++){
    values [i] = SPI.transfer(0x00);
Thank you for help.
Kind Regards
char values[10];
This isnt correct ?, is it? ..(or just a buffer?)
choose int or long
Hi knut_ny,
Thank you for reply. Yes that is buffer. Can I use signed int or just int/long? Sorry for basic questions but I am new in programming world...
Cheers
void setup(){
SPI.begin();
CS is active LOW.. Is this the bug?
Hi I have changed char with long and it seem to be working ok. Thank you for your help
