Hi everyone,
I'm currently working on a research project where I am using the ADXL355 accelerometer. I have carefully followed the instructions in the datasheet and other helpful posts on the forum to write my main source code.
#define DEVID_AD 0x00
#define DEVID_MST 0x01
#define PARTID 0x02
#define REVID 0x03
#define STATUS 0x04
#define FIFO_ENTRIES 0x05
#define TEMP2 0x06
#define TEMP1 0x07
#define XDATA3 0x08
#define XDATA2 0x09
#define XDATA1 0x0A
#define YDATA3 0x0B
#define YDATA2 0x0C
#define YDATA1 0x0D
#define ZDATA3 0x0E
#define ZDATA2 0x0F
#define ZDATA1 0x10
#define FIFO_DATA 0x11
#define OFFSET_X_H 0x1E
#define OFFSET_X_L 0x1F
#define OFFSET_Y_H 0x20
#define OFFSET_Y_L 0x21
#define OFFSET_Z_H 0x22
#define OFFSET_Z_L 0x23
#define ACT_EN 0x24
#define ACT_THRESH_H 0x25
#define ACT_THRESH_L 0x26
#define ACT_COUNT 0x27
#define FILTER 0x28
#define FIFO_SAMPLES 0x29
#define INT_MAP 0x2A
#define SYNC 0x2B
#define RANGE 0x2C
#define POWER_CTL 0x2D
#define SELF_TEST 0x2E
#define RESET 0x2F
#define ADXL355_CS_PIN 10
#define ADXL355_MOSI_PIN 11
#define ADXL355_MISO_PIN 12
#define ADXL355_SCK_PIN 13
#include <Arduino.h>
//#include <SD.h>
#include "SdFat.h"
#include <Wire.h>
#include <SPI.h>
#include <led.h>
//const int SD_CS = 8;
const int acc_CS = 10; //
long values[20],t[9];
double x, y, z, c;
volatile uint8_t ADXL355_DRDY;
volatile int ADXL355_DATA_COUNTER;
void acc_data();
byte readRegister (byte thisRegister);
void writeRegister (byte thisRegister, byte value);
SdFat SDO;
File myFile;
void GPIO7_IRQHandler(void) {
if (1) {
ADXL355_DRDY = 1;
ADXL355_DATA_COUNTER += 1;
SPI.setMOSI(ADXL355_MOSI_PIN);
SPI.setSCK(ADXL355_SCK_PIN);
SPI.setMISO(ADXL355_MISO_PIN);
SPI.setCS(ADXL355_CS_PIN);
SPI.begin();
pinMode(3, OUTPUT);
digitalWrite(3, HIGH);
pinMode(41, OUTPUT);
digitalWrite(41, HIGH);
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
pinMode(6, INPUT);
attachInterrupt(digitalPinToInterrupt(6), GPIO7_IRQHandler, RISING);
// digitalWrite(23, HIGH);
writeRegister(POWER_CTL, 0x00);
writeRegister(RANGE, 0xC1);
writeRegister(SELF_TEST, 0x00); // writing 0 to to enable sensor // 0x06?
writeRegister(SYNC, 0x00);
writeRegister(FILTER, 0x05); // 1000 Hz
ADXL355_DRDY = 0;
ADXL355_DATA_COUNTER = 0;
SDO.begin(SdioConfig(FIFO_SDIO));
LED_Init();
LED_Off();
ADXL355_DRDY = 0;
for (int i=0; i<4000*60*10; i++) {
while (!ADXL355_DRDY) {}
ADXL355_DRDY = 0;
acc_data();
if (i%10 == 0){
Serial.print(ADXL355_DATA_COUNTER);
Serial.print(',');
Serial.print(x,7);
Serial.print(',');
Serial.print(y,7);
Serial.print(',');
Serial.print(z,7);
if (i%1000 == 0){
LED_Gtoggle();
// acc_data();
// delay(3000);
byte readRegister (byte thisRegister) {
byte inByte = 0 ;
digitalWrite(acc_CS, LOW);
SPI.transfer((thisRegister << 1) | 1);
inByte = SPI.transfer(0x00);
digitalWrite(acc_CS, HIGH);
return inByte;
void writeRegister (byte thisRegister, byte value) {
SPI.transfer(thisRegister << 1);
SPI.transfer(value);
void acc_data(){
values[0] = readRegister(XDATA3);
values[1] = readRegister(XDATA2);
values[2] = readRegister(YDATA3);
values[3] = readRegister(YDATA2);
values[4] = readRegister(ZDATA3);
values[5] = readRegister(ZDATA2);
values[6] = readRegister(XDATA1);
values[7] = readRegister(YDATA1);
values[8] = readRegister(ZDATA1);
t[0] = readRegister(TEMP2);
t[1] = readRegister(TEMP1);
x = (values[0] << 12) + (values[1]<<4) + (values[6]>>4);
y = (values[2] << 12) + (values[3]<<4) + (values[7]>>4);
z = (values[4] << 12) + (values[5]<<4) + (values[8]>>4);
// Serial.print(x);Serial.print(",");
// Serial.print(y);Serial.print(",");
// Serial.print(z);Serial.println();
if (x >= 0x80000) {
x = x-(2*0x80000);
if (y >= 0x80000) {
y = y-(2*0x80000);
if (z >= 0x80000) {
z = z-(2*0x80000);
c=(t[0]<<8)+t[1];
c=((1852 - c)/9.05)+25.7;
x=x*0.0000039;
y=y*0.0000039;
z=z*0.0000039;
However, I have encountered an issue with the ADXL355 ODR settings. Despite setting the ODR correctly in my code, I have observed through an oscilloscope that the DRDY pin does not reflect the expected output.
Similarly, when I change ODR from 4000Hz(Addr:0x28->Val:0x00) to 125Hz(Addr:0x28->Val:0x05), each output doesn't give its exact setting value..
ODR=0 : (ideal) 4000Hz <-> (measured) 3968Hz~4098Hz
ODR=1 : (ideal) 2000Hz <-> (measured) 2000Hz~2032Hz
ODR=2 : (ideal) 1000Hz <-> (measured) 1012Hz~1016Hz
ODR=3 : (ideal) 500Hz <-> (measured) 502.5Hz~507.6Hz
ODR=4 : (ideal) 250Hz <-> (measured) 126.6Hz~252.5Hz
ODR=5 : (ideal) 125Hz <-> (measured) ~126.3Hz
Low odr even gives high difference..
Also It seems that data lost breaks out
I wanted to ask if anyone else has experienced a similar problem with the ADXL355 accelerometer. If so, I would appreciate any insights or solutions you have discovered to address this issue.
Thank you in advance for your help and suggestions.
Best regards,
