I'm trying to connect an ADXL362 with a ESP32 using the library ADLX362 by anne.
The code i'm uploading is the example ADXL362_SimpleRead
ADXL362_SimpleRead.ino - Simple XYZ axis reading example
for Analog Devices ADXL362 - Micropower 3-axis accelerometer
go to http://www.analog.com/ADXL362 for datasheet
License: CC BY-SA 3.0: Creative Commons Share-alike 3.0. Feel free
to use and abuse this code however you'd like. If you find it useful
please attribute, and SHARE-ALIKE!
Created June 2012
by Anne Mahaffey - hosted on http://annem.github.com/ADXL362
Modified May 2013
by Jonathan Ruiz de Garibay
Connect SCLK, MISO, MOSI, and CSB of ADXL362 to
SCLK, MISO, MOSI, and DP 10 of Arduino
(check http://arduino.cc/en/Reference/SPI for details)
#include <SPI.h>
#include <ADXL362.h>
ADXL362 xl;
int16_t temp;
int16_t XValue, YValue, ZValue, Temperature;
void setup(){
xl.begin(10); // Setup SPI protocol, issue device soft reset
xl.beginMeasure(); // Switch ADXL362 to measure mode
Serial.println("Start Demo: Simple Read");
void loop(){
// read all three axis in burst to ensure all measurements correspond to same sample time
xl.readXYZTData(XValue, YValue, ZValue, Temperature);
Serial.print("XVALUE=");
Serial.print(XValue);
Serial.print("\tYVALUE=");
Serial.print(YValue);
Serial.print("\tZVALUE=");
Serial.print(ZValue);
Serial.print("\tTEMPERATURE=");
Serial.println(Temperature);
delay(100); // Arbitrary delay to make serial monitor easier to observe
The pins connected are SCLK, MISO, MOSI, and CSB of ADXL362 to
SCLK, MISO, MOSI and CSB from the ESP32
I notice the lecture in the serial monitor is something like
(W��<
ڜɀ �aVW���l,�x��A� W�����N�o���'!�:��lTP���
But when I upload the same code to an arduino nano I can get an actual value. It is possible that this library does not work with the ESP32, and what can i do to solve this problem?
